Front strut replacement tips
Old Oct 21, 2024 | 06:43 AM
Grutella's Avatar
Default Front strut replacement tips
Hey
So I have a swaying movement, especially during lower speeds and when I'm cornering, after hitting a curb a little too hard. This was right before I swapped to summer tires, so I figured I'd wait and see if a tire change and wheel aligment would help, and it didn't. So I am thinking about changing the front struts (2001 S-type 3.0). I noticed that they are electronic, and I have no clue how to go about changing electric ones. I've seen videos on youtube of people replacing non-electronic ones though. I've read some people disconnect the electronic suspension module and just go with non-electric struts.
Any tips and ideas?
Which ones to buy etc?
Old Oct 21, 2024 | 08:31 AM
motorcarman's Avatar
The X200 has a common fault with the lower ball joints.
They seize and 'unscrew' the nut to the lower control arm.
Jaguar sells the entire vertical link but aftermarket ball joints can be installed.
Old Oct 21, 2024 | 02:04 PM
Grutella's Avatar
Should this express itself in a play in the wheel when trying to move it? I already have jacked that part up and checked both sideways and up/down motion and everything stays in place.
Old Oct 21, 2024 | 02:45 PM
When the ball joint nuts get loose, the car will 'wander' all over the road.
Steering will become very imprecise/vague.
Just check the lower ball joints as a precaution.
Old Oct 24, 2024 | 06:35 AM
Grutella's Avatar
Thanks, but I don't have these symptoms, my steering is fine. I did check this lower ball joint just now just in case but it was fine. My main symptom is like I mentioned, swaying up and down when cornering. Has to be a front strut.
So original questions still on the table.
Old Oct 24, 2024 | 08:23 AM
kr98664's Avatar
I replaced both front struts and one upper control arm on my ‘02. Details here, including some precautions to take:
https://www.jaguarforums.com/forum/s...l-arms-264748/
JagRepair.com - Jaguar Repair Information Resource
To replace just the struts, not all of those details will be applicable. Your situation will be slightly different with the electronic struts, but I think the overall process will be similar.
The strut fits inside the coil spring. You will need a spring compressor to separate them. It’s not difficult, but you do need to be careful due to all that energy in a compressed spring.
If you’d rather not deal with that aspect, you may be able to find a shop who will separate them for you for a small fee.
Another option is to find an aftermarket complete spring/strut assembly. These are marketed as a time-saving option for a shop.
Old Oct 24, 2024 | 09:05 AM
clubairth1's Avatar
Community Influencer
How hard did you hit the curb?
Possible damage of some kind since this started after the impact?
Old Oct 29, 2024 | 05:12 AM
Grutella's Avatar
I was driving approximately 30 km/h and was to drop off a date, and didn't slow down enough when I drove over the curb. It felt like a quite hard hit.
So yes I'm leaning that way.
Old Oct 29, 2024 | 05:22 AM
Grutella's Avatar
Thank you for the information Karl. Where can I find the proper torque specifications?
shashi27
Oct 6, 2022 06:35 PM
TylerB
Sep 6, 2022 11:41 PM
thegreatgarbanzo
Feb 14, 2022 06:16 PM
atrier3
Apr 15, 2015 02:29 AM
michjag
Mar 11, 2012 10:25 PM
