Gas smell thru heater vents
Small raw gas smell has increased to anytime heater is turned on ..now very strong... Recently replaced defrost motor so air blowing on windshield and order is coming thru all vents .. some gas smell when outside the car when running .. any possible location that could be the culprit?
Nothing easily located ..yet .
2006-S type R
2006-S type R
2006-S type R
2006-S type R
Wordman-
I've never experienced this myself but I just need to clarify something.
Is the smell actually a Gasoline smell or a smell like burnt exhaust? My STR has not have a blower motor issue as of yet but did it require the removal of the cowl or anything that seals the inside from the outside?
Last question..do you have a Check engine light on? If so have you read the codes? ( I know that was two questions but what the heck)
I assume you're referring to fuel/petrol but do you get any burnt oil or exhaust fume smells?
Either way, the foam seals around the cabin filter assembly in the engine bay would have well and truly perished by now so not only engine bay smells will be entering the cabin but also the engine bay heat will be entering as well.
I've just renewed all the seals on my cabin filter assembly as I had enough of the extra heat and breathing in burnt oil smells off the dried oil that had accumulated on the exhaust manifold heat shield before I changed both cam cover gaskets.
It's a bit tricky to get back the proper factory seal as some of the foam needs to be stuck in a certain way and some of the foam needs to hang loose and folded over on reinstallation of the two part assembly.
I have taken plenty of photos and intend to post soon.
We drive on the correct side of the road here but I assume the foam seal set up will just be a mirror image.
Haven't seen too much on anyone fixing this problem nearly all cars will have/will soon have by now.
Fixing this though will only eliminate you breathing this in and not the problem.
Thanks 😊.will look at sealing the engine compartment from the inside of my Jag Will get to a shop that can detect gas leak as well. Did not know of either of these options .. appreciate the directions so my action is effective . Wordman
Additional information. Yes it is a gas smell, not any burnt oil or other odor. Just replaced catylitic converters and 4 O2 sensors ..no codes ...will move forward as a gas leak appears to be most likely cause to investigate first ..thank you again
2006-S type R
2006-S type R
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
