Getting 2 codes
Old Jun 25, 2013 | 06:49 AM
msimmers6865's Avatar
Thumbs up Sincere Thanks Abonano
Originally Posted by abonano
Passenger Side - Easy to do. Driver's side - a challenge, but doable - you need to remove the fuel line that runs across the top of the driver's side cam cover.
Looks like you need to do the passenger side for sure (P0302 Code) but I would certainly do both sides as a precaution...
You need: (To do the job 100% right the first time)
Cam Cover Gasket (Driver's Side - Part No: AJ88285 / Passenger Side - Part No: AJ88400)
Each of the following parts are interchangable for each side - Quantities listed for 1 cam cover (multiply quantities X2 if doing both sides)
4 - Spark Well Gasket (AJ87206)
1 - VVT Gasket (AJ82856)
2 - Center Cam Cover O-Ring - where the 2 center bolts go (AJ87242)
14 - O-Ring style for all outer cam cover bolts (NCA 2575CA)
Make sure you have a 7mm gear head flex ratcheting wrench for getting to the bolts on the bottom of the cam covers - you'll thank me later...
That's exactly what I needed
Old Jun 25, 2013 | 06:50 AM
police666's Avatar
This should be a stickie
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
