Grille badge
Old Jul 25, 2023 | 03:42 AM
Alexander UA's Avatar
Default Grille badge
Hi everybody.
Can someone tell me the part number of this badge and does it even exist as a separate part?
Old Jul 25, 2023 | 06:32 AM
bydand's Avatar
https://www.sngbarratt.com/English/#...egory=BODY(576)
Have a look around the SNG Barrett site. For the model you have, as it is not the modern S type 1999-2008 type.
Old Jul 25, 2023 | 06:44 AM
Peter_of_Australia's Avatar
You'll also find them on Aliexpress when you search for "Jaguar logo" there... Might not be "as" original, but might do the trick...
Old Jul 25, 2023 | 06:55 AM
I just need for s-type 2000
Old Jul 25, 2023 | 06:56 AM
There are no such
Old Jul 25, 2023 | 06:59 AM
There are plenty of those on Aliexpress - e.g.:
https://www.aliexpress.com/item/1005...400000539452_1
https://www.aliexpress.com/item/1005...00000539452_32
Old Jul 25, 2023 | 07:12 AM
They are different and differ in size.
Old Jul 25, 2023 | 07:17 AM
bydand's Avatar
I know what you need it for but does not look like a standard original 2000 S type grill. Hence the link to SNG.
The badge looks like a similar pattern to the early s type wheel cap centre covers, but the diameter is unknown.
A wheel cap centre being od 58mm and the badge without rim 49mm.
Who made the grill chrome cover Arden? or some other custom shop.
Old Jul 25, 2023 | 07:20 AM
Which size outer diameter do you need?
Old Jul 25, 2023 | 07:29 AM
Quite right, the central part from the wheel cap fits, it is about 46-47mm in diameter, like the hole in the grille. I'm not sure about the chrome trim.
Old Jul 25, 2023 | 07:39 AM
Originally Posted by peter_of_australia
which size outer diameter do you need?
46мм
Old Jul 25, 2023 | 07:44 AM
Those here (for gear knob) are 42mm:
https://www.aliexpress.com/item/1005...800000740384_9
Old Jul 27, 2023 | 03:52 AM
M-e-l-l-o-w's Avatar
This is a 42mm grill badge from a MK2, and/or an E-type they are quite expensive.
https://www.ebay.co.uk/itm/225302606393
Make sure that it will fit your 2000 S-type as the size may be wrong.
Old Oct 13, 2023 | 11:09 AM
in my opinion it turned out well
scottjh9
Sep 23, 2021 03:35 AM
VicVegas84
Dec 30, 2019 04:08 PM
Jaaaggg
Dec 21, 2018 09:35 AM
Jennifer S Flavell
May 23, 2018 08:40 AM
emaraszek
May 10, 2013 06:18 PM
