head lamps
Old Apr 24, 2024 | 11:16 PM
knares's Avatar
Default head lamps
i am sure this has been asked before, but i cant find it
thinking of up grading my headlamp bulbs to LED
has anyone done this
how did it go
what globes did you find best
thanks
Old Apr 25, 2024 | 07:34 AM
S-Type Owner's Avatar
Halogen to LED?
The reflectors are wrong to maximize/focus the increased light output and the heat-sinks on the backs of most LED units require leaving the back covers off of the housings, leaving them open to the environment...
Old Apr 26, 2024 | 01:38 AM
grandhaze's Avatar
Default LED options
My solution...two 3 led bars... bright.. no issues with radiator temp
Old Apr 27, 2024 | 12:41 AM
LLLA's Avatar
https://www.jaguarforums.com/forum/s...trofit-277611/
Old Apr 29, 2024 | 12:26 AM
Rober2's Avatar
is that brightness legal in NSW? Can you turn them on without the headlight?
Old May 2, 2024 | 12:47 AM
grandhaze's Avatar
These LEDs are legal in NSW. Only turn on with high beam. The contrast with the standard (yellow) lights is always impressive. I remember changing incandesent sealed beams for Halogens back in the 70s and being impressed by the then New tech...
Old May 2, 2024 | 12:50 AM
Rober2's Avatar
Would you mind sharing where you got them? Cheers
Old May 2, 2024 | 01:01 AM
grandhaze's Avatar
Default Led lights
TJM about 5 years ago. Top 3 bolt to lower 3 and lower to base of intake. I checked underneath for wires , pipes etc.... then in went 2 inch roofing screws.. dont tell anyone. Then the usual wired into HB wire for relay power. The grill bars give a interesting light / shadow effect to the road but only detract about 5% of light. At least I can see where im going....
Old May 2, 2024 | 01:13 AM
Rober2's Avatar
thanks, I will try them
2002xtypejamo2956
Apr 30, 2022 10:23 AM
OnebadassXJR
Oct 7, 2018 06:57 PM
bcprice36
Feb 6, 2017 07:39 AM
DevilDog
Feb 18, 2015 09:16 AM
Frog
Feb 29, 2012 12:47 AM
