heat not working but a/c runs cold as ice??
Old Aug 25, 2012 | 01:59 PM
payroll416's Avatar
Default heat not working but a/c runs cold as ice??
Anyone know what could b the cause of this? Or had the same problem.? jag genius if ur still out here in Toronto pm me. Thanks
Old Aug 25, 2012 | 05:13 PM
I can't remember the last time I sawJag Genius posting.
I would start by disconnecting the lines to your heater core and trying to flush water through in both directions let us know how that goes.
Old Aug 25, 2012 | 05:21 PM
QuartzSTypeR's Avatar
Have you done any work with the cooling system recently? Without knowing what kind of car or engine or info, its harder to diagnose. It could be leaking coolant, low on coolant, have an air pocket, or a myriad of other issues.
Old Aug 25, 2012 | 09:23 PM
bfsgross's Avatar
payroll, norri and quartz make great sense: post your "Style" (car info.) and purge all air from coolant lines.
Old Aug 26, 2012 | 07:55 AM
payroll416's Avatar
Old Aug 26, 2012 | 07:57 AM
JagV8's Avatar
Could be DCCV? Stuck closed for a change.
Old Aug 26, 2012 | 09:38 AM
Brutal's Avatar
as someone that works for a dealer, your DCCV valve is stuck closed, replace it. But you can always go to the real
s t e a l e r s..you know the ones that say they know your car but really dont. And then spend your money and time and break your stuff cause they dont know how to take it apart or diag it
Old Aug 26, 2012 | 05:40 PM
payroll416's Avatar
k so how much u think for a dccv valve? n is it easy my friend owns a shop but he thinks its the heater control module whatever that is. thanks
Old Aug 26, 2012 | 06:15 PM
JagV8's Avatar
The Search feature here is your friend... Or a car parts place, maybe even an online one.
Old Aug 26, 2012 | 10:00 PM
Brutal's Avatar
partsgeek.com, iirc $65-230. I put the cheap one on my GF stype in Jan. So far so good.
On your friend, it may be the ACCM(auto climate control module, which is the ac faceplate assembly or a remote unit if you have navigation) So that would be a good guess. The problem with that is this, the ACCM being burned on the ground driver(1 or 2 or both) is that it is ALWAYS a symptom caused by a bad DCCV. So replace or repair it without changing the DCCV and itll do it again. wasted time, wasted money..
You have to pinout with a DVOM the 2 circuits to the DCCV while operating the temp control from ac to heat and monitor voltage on the circuits accessed through the left side of the dash. SO If you replace the DCCV be sure and check that the circuits are not blown too. If they are, repair 1 or both. NOw that all being said, many times roughly half or even less have damage to the ACCM. Be sure and blow through the heater lines while disconnected to blow out any crud.
Old Aug 27, 2012 | 06:52 AM
bfsgross's Avatar
What he (Brutal) said goes for me too.
Old Aug 27, 2012 | 01:34 PM
payroll416's Avatar
Old Aug 30, 2012 | 08:10 PM
payroll416's Avatar
Pretty sure parts geek doesn't ship to Canada. Maybe they do now but any links would b appreciated. Winter is coming.
Old Aug 30, 2012 | 09:24 PM
payroll416's Avatar
Old Aug 31, 2012 | 09:46 AM
Brutal's Avatar
Yes but you need to verify the vin split or style of dccv. The differance is a 3 pipe or a 5 pipe
Old Aug 31, 2012 | 05:01 PM
payroll416's Avatar
fast40driver
Apr 19, 2024 07:24 AM
1100me
Aug 27, 2020 11:37 PM
johnnie ryall
Oct 19, 2015 09:44 PM
johanasu
Sep 3, 2015 12:39 PM
mikebaker3
Aug 31, 2015 10:44 AM
