help
Old Jan 10, 2010 | 03:02 AM
steeley123's Avatar
Unhappy help
pls could anyone tell me why my s type tries to cut out when it's warm ( it's a 2000 w reg)
Old Jan 10, 2010 | 09:14 AM
tbird6's Avatar
Sorry you need to give us much more information. It could be dozens of things!
Old Jan 10, 2010 | 09:24 AM
JagV8's Avatar
If it does it at idle (so, low revs and little load on the engine), it's probably an air (vacuum) leak. Search for air leak and for PCV elbow. But yes, give more info!
Old Jan 10, 2010 | 09:28 AM
Jagtec1's Avatar
While driving? At idle? Under load/no load? Does it stumble, or just shut off? Does it (engine) actually shut off? Any warning lamps?
Provide as much info as possible if you can.
Old Jan 10, 2010 | 11:10 AM
steeley123's Avatar
Default help
sorry yes it tries to cut out when it is at idle the car some times cuts out but will restart with no problem and it drives ok, also sometime's it will idle at 1500/2000 rpm i have serviced the car fitted new inlet manifold gaskets, plugs filters but no change. i have noticed a hissing sound coming from the throttle body assembly on the inlet manifold is this normal? thanks
Old Jan 10, 2010 | 11:13 AM
steeley123's Avatar
p.s i used a code reader to see if anything was wrong but nothing. pps no warning lamps. no problem when cold only when at running temp
Old Jan 10, 2010 | 12:08 PM
JagV8's Avatar
hissing = air leak
there should be no air leaks!
If you have a decent OBD tool, you may find either or both of:
1. it's not running CL (closed loop)
2. fuel trims (especially at idle) are well away from 0%, showing fuel being added to compensate for the extra O2 (oxygen i.e. air)
(note: unless CL, fuel trims are not meaningful and usually show as 0)
Some like to use a little propane to confirm it but if you can HEAR it then it's quite a BAD leak!
The extra revs are probably it going OL (open loop) but it will just stop doing it if you fix the leak.
Old Jan 10, 2010 | 02:40 PM
steeley123's Avatar
thanks for your help i will look into that and let you know. do you think the throttle body could be faulty?
Old Jan 10, 2010 | 02:45 PM
jagmadjohn's Avatar
If you have the V6 its quite a common fault
Old Jan 11, 2010 | 05:29 AM
Jagtec1's Avatar
If you had a vacuum leak, it would most likely have a p0171 or p0174 (or both) code stored. Same goes for a throttle fault....there would be a code, and MIL. You say you have no warning lamps or codes.
I'd put a fuel pressure gauge on it and attempt to duplicate the issue. See what FP does when the fault occurs. Just to rule out the simple stuff.
Old Jan 11, 2010 | 11:37 AM
steeley123's Avatar
ok thank i'll give it a wirl and see what happens and let you know
cheers
Old Jan 11, 2010 | 11:44 AM
JagV8's Avatar
A P0171 or P0174 isn't guaranteed. The hissing needs an explanation if it's not an air leak. Fuel pressure appears very rarely a problem with S-Types. Diagnose the cause of the hissing first. And if it is an air leak then fix it urgently.
Old Jan 11, 2010 | 07:15 PM
Jagtec1's Avatar
V6 or V8?
JagV8, you are correct....there is no guarantee that a code would be stored....I would tell him to look at fuel trim , but chances are he does not have that capability. To the OP, if you can look at fuel trim, please do....and report back.
