HELP! // Enter system pin
Old Nov 11, 2008 | 10:22 AM
sprabg's Avatar
Default HELP! // Enter system pin
Hello Jaguar owners,
I am a Jag S-type 2003 owner and I have a problem with my system. It appeared after I took my car at the service, where they replaced some parts.
After I got my car the Navi screen had this "Enter system pin" message and I don't know what it is all about.
It's a 4 digit pin code that should enable my system to full funcionality (as listen to radio and CD, navi and all that...)
The problem is that I entered 3 times different codes and it the system seems to be blocked.
My questions are:
Why did I get this system pin message at all, having in mind that everything was working perfectly when I left my car at the service?
And How can I get things work again?
I would appreciate any help and comments.
Thanks and all the best,
I.N.
Old Nov 11, 2008 | 10:38 AM
whiteSTR's Avatar
Default RE: HELP! // Enter system pin
[sm=groupwave.gif]
Old Nov 11, 2008 | 11:01 AM
Brutal's Avatar
ITS ASKING FOR THE RADIO CODE WHICH SHOULD BE ON A CREDIT TYPE CARD WITH YOUR OWNERS MANUAL AND BOOKS, IF NOT CALL THE DEALER BACK AND HAVE THEM LOOK IT BACK UP FOR YOUR VIN IN DDW. ONCE YOU ENTER THE WRONG CODE 3 XS YOU HAVE TO LEAVE THE IGNITION ON 45 MINUTES TO AND HOUR. AND RIGHT THE NUMBER DOWN CAUSE ANYTIME THE BATTERY IS DISCONNECTED ITLL ASK FOR THE CODE
Old Nov 11, 2008 | 02:25 PM
sprabg's Avatar
Thank you very much for the quick responces and the useful information and suggestions!
Tomorrow I will check it out and write back. I really hope to get things working tomorrow. I will see is there any clue on my manual.
Thanks again!
I.N.
Old Nov 12, 2008 | 12:47 PM
sprabg's Avatar
Hi again!
So today I switched the ignition on and after some 15-20 minutes it was ready to enter the pin again. I checked at my Jag manual, where I found a card with a pin code written on it, so I entered it and everything started to work perfectly.
Thank you very much for the help, especially to BRUTAL.
I.N.
Old Nov 12, 2008 | 01:04 PM
H20boy's Avatar
I.N., take that manual to bed w/ you one night, read it and learn all sorts of neat things about your car. I'm glad to hear you found a quick and easy solution to your problem. You stickin around or am-scrayin?
Old Nov 19, 2008 | 08:09 AM
sprabg's Avatar
Yeah Thanks for the suggestion h20boybut I've got my manual in German and I know no German so this is why I haven't still gone over it.
What do you mean by am-scaying?
Old Nov 19, 2008 | 12:48 PM
harounq21's Avatar
ORIGINAL: h20boy
Global Open for example will either be your best friend or your worst enemy.
Old Nov 19, 2008 | 03:03 PM
H20boy's Avatar
Sorry sprabg, poor pig-latin. am-scray -> scram. You sticking around?
Hey buddy, check this out. Its in English!
Old Nov 20, 2008 | 06:28 AM
sprabg's Avatar
This is awesome!!!!! BIG THANKS
Old Oct 23, 2015 | 03:54 AM
jagnew's Avatar
Hello to all veteran Jag owners,
I just got an XJ6 2004. It did not have the navigation CD/DVD. The display inside is asking me to enter the system PIN. The PIN seeems to be a 4-digit number. I tried many standard PIN looking numbers like 0000, 9999 1234 1111, etc... but none of them worked. As I read in the thread, it says that there should be a card (with the manual) with the PIN written on it. I have neither. Is there any way to get the PIN with the help of my VIN/ Chassis number. Without this PIN I cannot use any function on the display (except the climate control). Also, where do I get the Navigation CD for it ? Is the PIN issue related to the Navigation CD in any way ?
Please help with all possible advice.
Thanks.
Old Oct 23, 2015 | 10:33 AM
tbird6's Avatar
Well follow Brutals instructions. Have you called the dealer with your VIN?
Old Oct 25, 2015 | 05:12 AM
jagnew's Avatar
The dealer's like getting ripped off. So I thought I may first look at other avenues. But guess I may have to go to the dealer now. Will keep you all updated with the results in few days.
Thanks to all.
1100me
Jul 24, 2023 06:10 PM
cissdm
May 3, 2016 06:02 AM
Charlene n John
Sep 14, 2015 12:01 AM
Saturbo
Sep 8, 2015 07:35 PM
Sprayall
Sep 3, 2015 07:49 PM
