how can i check the tranny fluid on a 01' s-type?
Old Oct 4, 2010 | 07:49 AM
digimurda's Avatar
Default how can i check the tranny fluid on a 01' s-type?
3.0 engine.
Old Oct 7, 2010 | 01:55 PM
xjrguy's Avatar
Here is the drain & fill procedure for the Ford 5R55N transmission.
File Type: pdf
Old Oct 7, 2010 | 03:32 PM
motorcarman's Avatar
I would add one word of caution and try to remove the small allen or torx plug in the drain/stand pipe before draining the fluid. If the small level plug is too tight and strips then you will have no way to correctly check the fluid level. I always keep a spare drain/stand pipe (XR852333) because some are overtight or the locking sealant sticks it tight. The later ones should be TORX and early ones were ALLEN.
The TEMP range for fluid level checking is stamped on the rear of the gearbox.
bob gauff
Old Oct 7, 2010 | 03:37 PM
xjrguy's Avatar
Absolutely right! I keep one on hand as well. Though honestly, I haven't had one give me any trouble in 3-4 years.
Old Oct 7, 2010 | 05:16 PM
digimurda's Avatar
Should i drive the car before checking it?
Old Oct 8, 2010 | 07:52 AM
xjrguy's Avatar
No, do not drive first. You know I thought something was missing from that procedure. The level should ideally be checked at 100 deg. F, but the allowable range is 80-20 deg. F.
Driving the car first will most assuredly take the temp too high. The intent is to use a scantool capable of monitoring the trans temp while doing the level check. Not everybody can do that.
Good luck!
Old Oct 8, 2010 | 08:10 AM
Just use a non-contact laser thermometer on the pan and it will be plenty accurate.
bob gauff
Old Oct 9, 2010 | 11:11 AM
digimurda's Avatar
And attachment is for a 01' s-type?
Old Oct 9, 2010 | 12:24 PM
xjrguy's Avatar
Yes sir! Applies to all S-Types thru 2002 model year, unless you happen to be somewhere in the world that they used a different transmission that I am not aware of. All in the North American market used the Ford 5R55N gearbox.
Old Oct 9, 2010 | 02:29 PM
Leedsman's Avatar
Note: The reason for checking ATF fluid level at a partic. temperature is because the viscosity improvers in the fluid expand considerably when hot. This is how viscosity improvers work, they are intended to expand.
Leedsman.
aholbro1
Dec 29, 2024 06:46 PM
Sprayall
May 30, 2021 08:13 AM
neruda
Oct 18, 2015 01:19 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
Sprayall
Sep 3, 2015 07:49 PM
