How to get to trunk? HELP PLEASE
Old Jan 1, 2009 | 08:08 PM
snooktarpon's Avatar
Default RE: How to get to trunk? HELP PLEASE
There is keyhole on the trunk door just above the license plate (it hidden from normal viewing height but you can see it when you look from knee level). I'm assuming that will open the trunk with the battery.
I've attached an excerpt from the 2005 manual about trunk locking.
[IMG]local://upfiles/3449/78256E80F07340DD947D80BD47AC27FB.jpg[/IMG]
Old Jan 1, 2009 | 09:48 PM
Brutal's Avatar
OR ARE YOU REFERRING TO THE OFTEN FEATURE OF A KEY CYLINDER THAT HAS PROBOBLY NEVER BEEN USED SINCE YOU HAVE REMOTES AND BUTTONS TO DO THAT NOW, AND THE CYLINDER IS IN NEED OF A GOOD OIL SOAKING? iF THATS THE CASE SOAK WITH WD40 OR SOMETHING SIMILAR, AND IF THAT DOESNT WORK YOU CAN MAKE UP SMALL JUMPER WIRES TO POWER UP THE ENGINE COMPARTMENT FUSE BOX ON ONE OF THE UN USED SPADE TERMINAL. THIS WILL GIVE ENOUGH POWER TO POP THE TRUNK WITH THE REMOTE...
Old Jan 2, 2009 | 01:11 AM
jaakennuste's Avatar
BMW (battery also in the trunk) has clear battery terminals in the engine compartment, good for re-charging, pity that Jag hasn't. Still, key should work...
-Jack
Old Jan 2, 2009 | 09:08 AM
bigdaddywuff's Avatar
There is a 10mm i believe brass bolt inside the front engine compartment under the hood on the pass side. Use a power source by attaching the positve source to that bolt and ground the neg and you will get enough powere to open the trunk. Hope this helps this happen to me once and i was given this same help and worked like a charm.
Old Jan 3, 2009 | 09:54 AM
12RM's Avatar
ORIGINAL: 123ABC
I tried to use both of the keys that I have for the car, and none of them work.
If the keys are the correct ones you are not turning them far enough to action the lock. May need some lubrication if not used for some time.
Old Jan 3, 2009 | 12:10 PM
ORIGINAL: bigdaddywuff
There is .... pass side. U
Pass side? Left or right?
J
magmedia
Aug 15, 2019 08:54 PM
bdboyle
Nov 6, 2015 02:07 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
magmedia
Oct 8, 2015 03:28 PM
