how to hard reset
Old Jul 14, 2010 | 06:35 PM
davewhitt's Avatar
Default how to hard reset
hi from the uk .
when you guys do a reset ,whats the thing with the negative cable ,do you take off pos and neg then touch them together .or just take off the neg and touch that to the positive side still connected to the battery.
we just take off the battery .
Old Jul 15, 2010 | 12:58 AM
H20boy's Avatar
Originally Posted by davewhitt
hi from the uk .
Yes.. Ok, i'll be specific. Remove the negative cable from the battery, and touch the positive terminal, small spark (discharge) then hold for about 5 seconds. Reattach to negative terminal, and that's it.
taking off the battery doesn't immediately clear the memory all modules, there could be some stored power...that's why a touch to + saves the wondering, plus its much quicker.
Old Jul 15, 2010 | 01:12 AM
JagV8's Avatar
I'd wait a minute at least rather than cause such a spike!!
Also, it will only clear some module(s) - the ones with volatile memory (like the RAM in a PC). It won't clear all the modules with non-volatile memory (EEROM, flash, etc).
The PCM's KAM (keep alive memory) will be cleared (so the PCM will have to re-learn a lot of needed values such as how to idle smoothly and how to detect misfires and if it's already got misfires it will learn bad stuff as being normal!). The TCM (2003/3+ cars) isn't cleared and lots of other modules also aren't. You need a dealer-type OBD tool to clear those.
Old Jul 15, 2010 | 01:18 AM
H20boy's Avatar
It's not a spike, come'on, you're exaggerating it a little bit. Its smaller than static discharge from shuffling your socked feet on a carpeted floor and opening the refrigerator.
Old Jul 15, 2010 | 01:29 AM
JagV8's Avatar
It's directly connected to every expensive module in the car. I may or may not be exaggerating but I believe in not taking risks with those modules
Old Jul 15, 2010 | 06:14 AM
joycesjag's Avatar
I agree with jagv8, lots of sensitive electronics, to risky for me. I would spend the 100 euro(?) or so and take it to the dealer to be properly diagnosed then cleared, and I am not a dealer type of guy but sometimes worth the money.
Old Jul 16, 2010 | 08:16 AM
JagV8's Avatar
Well..... just to clarify - if I actually wanted to clear KAM (e.g. after fixing an O2 sensor or the MAF), I would do so and the cheap and safe way is to disconnect the battery. But I'd do that and wait, i.e. leave the battery off for a few minutes.
But it would already be disconnected during the type of repair I've just mentioned. (If I were doing the repair.)
I'd reconnect swiftly so as to get a good solid connection and have it stay that way. Electrical spikes? No thanks. As few as possible.
Old Mar 5, 2022 | 02:33 PM
RC419's Avatar
Hi. I recently did a hard reset on my jaguar 2003 xtype and now it's not turning over when I turn the key. Thing is it was going before I did the hard reset. I've checked all the fuses. You can start the car from the starter motor. Now when I turn the key I have a lot of clicking noise on the dash. Please help.
Old Mar 5, 2022 | 03:49 PM
User 42324's Avatar
You've posted in a 12 year old thread in the wrong forum. May I suggest starting a new thread of your own here:
https://www.jaguarforums.com/forum/x-type-x400-14/
max224
Jun 21, 2024 12:17 PM
ricwel
Jun 23, 2023 05:14 PM
Johnken
Apr 8, 2018 10:21 AM
goges
Oct 5, 2015 04:53 PM
JTC3400
Sep 29, 2015 05:03 PM
