How to remove interior trim squeaks and creaks?
Hi everyone, I wanted to know if anyone here has done anything to reduce interior creak noises? If I pull or push against a closed door there is definitely a good amount of creaking noise coming from what seems to be the door trim. It's also noticeable when driving over bumpy roads (the STR is not the most forgiving suspension).
I noticed a technical bulletin from Jaguar calling for application of an anti-friction gel called PEOX 612 Gel. It looks like that it is now called PEOX DF.
Any thoughts?
Any thoughts?
I'd also suggest checking the fastener clips that secure the door panels. They should have a black rubber washer to help reduce squeaking. On my car, several of the washers had disintegrated. Here are the aftermarket replacements I picked up, which have worked fine on my '02:
Note the Jaguar part number C2S13494 if you'd prefer to search for OEM pieces instead.
texevora
Dec 26, 2018 11:01 AM
itsmiami
Dec 12, 2014 02:24 AM
