How to replace passenger side sway bar bushing
Old Mar 23, 2010 | 08:12 PM
fwilder's Avatar
Default How to replace passenger side sway bar bushing
Hi all,
I've replaced the driver side sway bar bushing, but can't seem to get to one of the passenger side bolts. Any help would be greatly appreciated. The clunk seems better, but I think it's only half fixed. Go figure.
Old Mar 23, 2010 | 11:02 PM
Brutal's Avatar
bend the heater control valve and its bracket up with with a pry bar.you dont need much to get a short wobbler extension and 13mm socket in there. take out the bolts. change the bushing and reinstall. then bend tha bracket back down in place. it harder on a v8 than a v6 cause theres not as much room
Old Mar 26, 2010 | 12:28 PM
fwilder's Avatar
So do I disconnect the heater control valve from that mount first or just bend the whole thing.
Old Mar 26, 2010 | 01:10 PM
Brutal's Avatar
you just bend the whole thing up slightly, dont have to disconnect anything
what year do you have anyway?
Old Mar 26, 2010 | 02:34 PM
fwilder's Avatar
Okay thanks it's an 02 3.0
Old Mar 26, 2010 | 03:38 PM
Brutal's Avatar
then yes its as I stated for repair and probobly still has the old style sway bar bushings that seperate at the bottom instead of the side as the new style do
Old Mar 26, 2010 | 04:16 PM
fwilder's Avatar
Yep. the driver side split on the flat side and the new ones split on the side. Man, I hope this fixes the problem. I hate that clunky sound.
Old Mar 26, 2010 | 05:38 PM
H20boy's Avatar
you'd be surprised what those little bushings absorb... check back in when you're thru.
Old Mar 26, 2010 | 09:44 PM
Brutal's Avatar
at least that noise yes, the easy diag for sway bar bushings is...while slowly driving make the car rock side to side with the steering wheel. if it knocks its the sway bar bushings...
philwarner
Dec 6, 2021 07:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
91xjscoupe
Sep 1, 2015 12:01 PM
frankc
Sep 1, 2015 04:41 AM
perfectphoto
Aug 29, 2015 10:11 PM
