idle problems 2003 jaguar S type 3.0l
Old Apr 22, 2014 | 11:27 PM
bighoks's Avatar
Default idle problems 2003 jaguar S type 3.0l
about 6 months ago my check engine light came on. had my friend put his scanner on and check it, the car came back with p1646 i ran the car until it finally stopped running and had to be towed home, i finally ordered the o2 sensor and changed it out today, tried starting the vehicle after changing the o2 sensor( bank 1 upstream sensor) it started but quickly died out, i disconnected the battery for 30 minutes and tried to restart the car, the car started up fluttered a bit then went back to idling like nothing was wrong I took it around the neighborhood and it drove fine, when i got home i turned the vehicle off and tried to start it back up, it would start but quickly starts to idle roughly and then dies out. i dont know what else to check because the scanner is not reading anything but the p1000 DTC
Old Apr 23, 2014 | 02:24 AM
JagV8's Avatar
Wrong sensor? Fitted badly? Failing battery?
Old Apr 23, 2014 | 03:47 AM
bighoks's Avatar
the sensor was the exact same one that came out of vehicle, now after cranking the car so many times the battery is starting to die, the vehicle ran for about ten minutes after changing the sensor but now it just cranks up sputters and dies out, seems like its not getting gas
Old Apr 23, 2014 | 04:45 AM
JagV8's Avatar
Did car sit for a while? Seems to kill fuel pumps. Also, maybe change fuel filter. Either way, check fuel pressure.
Old Apr 23, 2014 | 04:47 AM
bighoks's Avatar
car sat for about 3 weeks since it got towed home, gonna change out the fuel filter tomorrow, and check the fuel pressure also. what is the fuel pressure supposed to be at? also forgot to mention i got a P0191 code when i ran my scanner on the car
Old Apr 23, 2014 | 05:18 AM
police666's Avatar
see attached pdf
File Type: pdf
Old Apr 23, 2014 | 06:27 AM
JagV8's Avatar
That's a fuel pressure code so ....
Codes PDF is in stickies and in JTIS, both free download
Old Apr 23, 2014 | 07:30 PM
bighoks's Avatar
changed fuel filter then started it, got 40psi but the car was running rough, then i turned car off disconnected the fuel pressure gauge and now the car doesnt want to start, i reconnected the fuel pressure gauge and now im not getting any fuel pressure, could it be the fuel pump? or the fuel pressure regulator?
Old Apr 24, 2014 | 01:32 AM
JagV8's Avatar
40 is low. None suggests the pump.
Old Apr 24, 2014 | 01:42 AM
bighoks's Avatar
Would the maf sensor have anything to do with it not running after I try starting the vehicle
Old Apr 24, 2014 | 05:48 AM
police666's Avatar
see post number 6
Old Jun 13, 2014 | 05:10 AM
bighoks's Avatar
Changed the fuel pump today and I'm getting a rough idle and car starts intermittently, it will start then die out then after a couple tries the motor will sputter then idle at 1000rpms but with a bad idle. I'm at a stand still and can't figure out what is wrong with the car.
Old Jun 13, 2014 | 07:30 AM
Did you follow the troubleshooting guide in post #6?
stanjag
Dec 29, 2024 08:26 PM
nelsonht
Aug 30, 2015 06:01 AM
swarm27
Aug 29, 2015 07:37 AM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
Terrance Williams
Aug 26, 2015 11:50 AM
