J gate sticks in p
Old Dec 29, 2024 | 02:00 PM
Frank koper's Avatar
Default J gate sticks in p
Hi all
Im frank from Holland
Last Saturday i buy a s type a 3.0 v6 build 2000 a mk 1
It drives very well only when cold ( even after pressing brake) it gets difficult out of p not always
When in drive it shifts very smooth so much different than my previous car also British rover 75 2.5v6
It haves some small work
Today fixed driver seat movement the connection from motor to other side was out of place now works again
Of course 20 year old so maintenance has to be checked needs new brake discs and brake pads
New oil oil filter airfilter sparkplugs luxe have room in enginebay ( 75 was very full)
Headliner is a wish( have open roof) a pilar already ordered
Have also ordered storage compartment besides radio. Now there is. Kind of telephone holder that old its not usable
Im looking for cupholder besides handbrake they dit saw a pice out
Also miss lid ashtray
The original radio gets replacement of a 2 din touchscreen with navi dab ect. Also make wifi in it
Outside only 2 very small dents need work
That all for 1450 Eur
Got 1100 for my 75 what had lot of problems
Color is dark green metallic
Its just how light falls sometimes blue sometimes black ore green super color
Im gona order a ornament cat for engine Bonnet
Wat that leaping cat on it thats for now
Frank
Old Dec 29, 2024 | 02:53 PM
Rober2's Avatar
Frank, welcome to the forum. Congratulations on your new car. First, follow the link to introduce yourself.
https://www.jaguarforums.com/forum/n...-up%2A-241802/
On your J gate issue, a simple temporary fix is to use N unless P is needed for safety. Here is a thread on the gate issue. It may be a different issue than yours but search the Stype forum and there are bound to be more.
https://www.jaguarforums.com/forum/s...-found-123379/
Notice my signature?
Old Dec 29, 2024 | 04:05 PM
JagV8's Avatar
Being a 2000 car it may be a stretched shift cable. If it is, it might adjust or else need replacing.
In case it's electrical, check the guide for your era car - will be on JagRepair.com - Jaguar Repair Information Resource
Old Dec 29, 2024 | 04:12 PM
Rober2's Avatar
I want 8 more STs, one for each year.
Old Jan 11, 2025 | 08:40 AM
Found the problem
Its the solenoid what's not working ok
I noticed that sometimes it works
For now i take it out.and shifting good
Here in Holland almost all road are flat
So no big deal, and avantage i use handbrake more often
If i find One i put it in again
Old Jan 11, 2025 | 10:31 AM
motorcarman's Avatar
Things we dealt with when the X200 was introduced.
Old Jan 11, 2025 | 03:52 PM
kr98664's Avatar
Originally Posted by Frank koper
Found the problem
Make sure the brake lights work properly. IIRC, the same switch (on the pedal) controls the shift lever interlock and the brake lights. If the switch is bad, the interlock solenoid may be okay.
On the early models, there's a common scenario with the transmission that may leave you stranded if you don't always use the parking brake. The transmission itself (not the lever) can get stuck in park, especially if on an incline. Then if you're really unlucky, there's a fragile plastic piece in the J-gate assembly that breaks if you pull too hard on the lever. More details here, including a very simple procedure (in post #3) to follow when parking:
https://www.jaguarforums.com/forum/s...ncline-183486/
Old Jan 11, 2025 | 06:39 PM
When the parking pawl gets 'jammed' on the 5R55N (on an incline?) you need to 'rock-the-car' back and forth with someone attempting to move the selector lever out of park.
I instructed customers to ALWAYS use the handbrake and the one's that heeded my warning don't have issues.
Stop and use the handbrake, THEN put the selector lever in PARK. (in that order)
Old Jan 16, 2025 | 04:42 AM
GlynS's Avatar
Do you suggest doing the same Stop, use handbrake and then selector lever in Park for the later s-types as well. I have a 2004 model and had issues with the car being stuck in Park.
Old Jan 16, 2025 | 07:20 AM
Rober2's Avatar
I have an 01 and I can remove the key when it is in N. On my newer car, the gear needs to be in P before I can remove the key. If your car will allow key removal on N, I will use handbrake instead of P.
Old Jan 16, 2025 | 08:37 AM
The later models have the electronic parking brake which is applied automatically.
Old Jan 16, 2025 | 09:38 AM
kr98664's Avatar
I'm not well versed with the later models so can't offer any advice about whether to apply the parking brake manually or let the automatic function do it.
As far as the "car being stuck in Park", do you know if it is the shift lever or the transmission which is not cooperating? Within the J-gate assembly, there's a solenoid-operated lock which prevents moving the shift lever from Park unless you've applied the foot brake. When this lock is engaged, you can only move the lever a short distance, perhaps a few mm, and then it hits a hard stop. If the lock is releasing properly, but the transmission itself is restricting the lever movement (via the shift cable), you can move the lever further with no hard stop, so the end of travel feels a bit more spongey. Big difference in how to troubleshoot, so please let us know.
Later models also have a known problem with the 2 bolts which secure the shift cable to the side of the transmission. Not sure if they'd cause your issue if loose, but it's worth checking them. More details here:
https://www.jaguarforums.com/forum/s...l-bolt-269294/
Old Jan 16, 2025 | 09:55 AM
Its pure the j gate now solenoid is removed it works like it should
QP7
Jan 24, 2024 11:52 AM
Venus911
General Tech Help
Aug 9, 2016 08:03 AM
catterwaller
May 26, 2016 04:05 PM
JayYu
Feb 5, 2015 03:23 AM
boobea
Mar 4, 2012 01:12 PM
