Jagar S type global locking
Old Sep 4, 2012 | 03:34 AM
harris24742's Avatar
Default Jagar S type global locking
Global locking/closing.*
Jaguar stype 2001
The car opens evrythng when the unlock button is held on the transmitter but it doesnt closes or locks the vehicle if the lock button is kept held.*
The sunroof nd windows can b closed by the putting the key in the lock and rotating it in the locking direction.*
Strange; everythng opens up when unlock button is held bt the opposite doesnt occur
Old Sep 4, 2012 | 05:00 AM
barney100golf's Avatar
If you have a spare fob does that work, I suspect that the button has failed you can buy new buttons, but you would need to be able to use a soldering iron, but you could try just cleaning the button first with a good electrical contact cleaner or with some meths on a cotton bud
Old Sep 4, 2012 | 05:53 AM
I'm not sure that global closing works on the pre 2002.5 models as they didn't have the safety mechanisim fitted.
I could be wrong.
If it is fitted it needs to be dealer activated.
Old Sep 4, 2012 | 06:57 AM
I could be wrong.
I could be wrong but the poster seems to be saying the remote will not lock the car? let alone global close
Old Sep 5, 2012 | 04:40 AM
The carvis fitted with global lock/close.
The key does this function. It can global open and lock/close the car if it us inserted in the key hole and held in the respective positions for the said functions.
The remote is functioning well. I believe that the closing button is working since it locks and double locks the vehicle.
Old Sep 5, 2012 | 04:13 PM
That is how it is supposed to work, I should have said global closing from the fob only works after 2003.
File Type: pdf
Old Sep 6, 2012 | 04:30 AM
Okay clear abt it nw.
Nw m left wid ither probs
The halogen headlamps are nt adjusting by the adjusters on the assembly. I guess they are broken nw. The left headlamp is far too high.
The thumbwheel located inside the car at the lower left of the steering wheel is i guess nt adjusting the headlamps. How do i knw that i have auto headlamp adjustment function.
Can i put an oem xenon headlamps from a s type having them.
I need o wire my autodimming mirror. I have replaced tye screen. Just need to give power to the mirror so it is on.
The rear left door lock stucks when locked or unlocked from the key or the remote. I guess its too hard to be moved by them. It is okay if i manually lock or unlock.
Pls do post solutions or appropriate links
To the solution. No second guesses and search suggestions. M too lazy for them.
Thnku. .
D.K
Dec 10, 2023 02:05 AM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
tberg
Sep 7, 2015 07:32 AM
dcvickers
Sep 2, 2015 06:14 PM
