Jaguar S type 2002 No Start Please Help!!
Old Sep 4, 2012 | 10:02 AM
chaddm55's Avatar
Default Jaguar S type 2002 No Start Please Help!!
I've been having a problem with my jaguar when trying to start it where the starter will turn, but the car will not start until about 8 to somtimes 25 tries. I just replaced the fuel pump, sender and fuel filter and it worked for a day than on the second day it went back to taking awhile to start which makes me know something else is wrong. Check engine light is on and its running lean in bank 1 and 2 because of a vacuum leak that is getting fixed but i dont think that is the case. Sometimes when it does fire up after a few turns, it seems to want to stall making me turn key back to off. After a few times it than fires right up running great. When running awhile if I turn the engine off and run in a store it fires right back up. It also seems to give me problems after it sits for awhile. SOMEONE PLEASE HELP!!! Shop seems to be clueless and has me worried....Sometimes when I pull the key out its HOTT!!!
Chadd Martin
Old Sep 4, 2012 | 10:27 AM
steveinfrance's Avatar
Chad - I've moved your post to the S Type section where you'll get more help, and deleted the duplicate.
Please take time to visit the New Members section and introduce yourself.
Old Sep 4, 2012 | 10:48 AM
OxfordTheCat's Avatar
I had some issues starting up when I first got the car (in the dealer parking lot, as a matter of fact) that turned out to be a bad battery.
The battery read as charging fine, but the car wouldnt start. A new battery fixed the issue instantly.
I'm a new owner, so I'm sure other people on the forum have more insight, but that might be a place to start.
Old Sep 4, 2012 | 12:22 PM
What codes are you getting Chadd?
Old Sep 4, 2012 | 03:23 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
I'm bettin the battery needs to be replaced realllll quick...
Old Sep 7, 2012 | 11:53 AM
chaddm55's Avatar
Default problem
I am getting a code lean in bank one and 2. Thats the only codes which is why I am getting vacuum leak fixed but it makes me wonder if a vacuum leak could cause that much of a problem. And I doubt its the battery because it has full power and turns over to start just seems like it wont fire and when it does it stutters till it stalls.
Old Sep 7, 2012 | 11:58 AM
chaddm55's Avatar
And I can sit and detail car and listen to music forever without having to jump it. So confused because I know jaguar's are huge on electrical. Could it really be the battery still? Makes me feel like something in the car is telling the fuel to not kick on but after a few turns and I mess with it, it turms right over (or turns over than wants to putter and stall till I turn off than on again and it fires right away...
Old Sep 7, 2012 | 08:39 PM
bfsgross's Avatar
Battery. The S-Type battery is large thus hides weak cells very well.
Old Sep 8, 2012 | 08:18 AM
abonano's Avatar
The short answer to your question would be...... NO...
Old Oct 8, 2012 | 05:07 PM
dav2ph's Avatar
Default 2002 S-Type Jag ,,Not Getting Any Gas !!!
I replaced the fuel pump,I replaced the crank sensor,i check the fuses,and relay's.
I'm using a light tester now to see if it is getting any fire to the fuel pump,,,( NOT GETTING ANY FIRE TO FUEL PUMP)
Old Oct 8, 2012 | 06:23 PM
abonano's Avatar
Check the inertia switch (driver's side under dash panel forward front door) make sure the button is fully depressed.
Old Oct 9, 2012 | 07:56 PM
dav2ph's Avatar
Smile 2002 S-Type Jag ,,Not Getting Any Gas !!!
Problem Fixed !!!
The reason i was not getting any fuel was a simple fuse,,Guys Make sure you check your fuses very careful,cuz i over looked the simple fuse in the rear fuse box,,,THANKS GUYS FOR ALL YOU HELP!!!
Old Oct 10, 2012 | 05:23 AM
joycesjag's Avatar
WTG dav2ph.
Now I wonder where the OP stands. Hey chaddm55 any updates?
Old Oct 17, 2012 | 01:59 PM
srdann's Avatar
Default Chad
Chad have you fixed it yet? I'm having the same problem except mine runs fine once it starts. Problem seems to occur only on initial start. Shop insists its the fuel pump and wants $1000 to replace it.
nelsonht
Aug 30, 2015 06:01 AM
swarm27
Aug 29, 2015 07:37 AM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
sorken88
Aug 28, 2015 04:09 AM
Terrance Williams
Aug 26, 2015 11:50 AM
