Jaguar S-Type R problem !
Old Aug 23, 2021 | 11:13 AM
^SiRtA^'s Avatar
Originally Posted by xalty
you don’t need topix to reprogram with sdd in legacy mode. you need a half decent j2534 cable. the da-dongle is the cheapest and JLR approved. forget about the mongoose, real or fake.
I was right, I always thought! How can i find dadongle, on ebay ?
i also know a guy who was selling vcm 1 cables. i’ll try to source it for you if he still has them.
Oh thankyou ! I love my vcm (genuine)
Old Aug 23, 2021 | 11:27 AM
^SiRtA^'s Avatar
I've found Da Vina ... ?
Old Aug 23, 2021 | 11:29 AM
xalty's Avatar
https://www.diagnostic-associates.co...thru-interface
you can buy a new cable for your vcm for about the same price
Old Aug 23, 2021 | 06:54 PM
^SiRtA^'s Avatar
Ahemmm see image... stype support : NO
Old Aug 23, 2021 | 06:57 PM
^SiRtA^'s Avatar
I hope i can buy a cable for my genuine VCM
Old Aug 24, 2021 | 07:11 AM
^SiRtA^'s Avatar
I think i can buy teradyne module Exist a shop with this pcmcia?
Old Aug 24, 2021 | 11:27 PM
Cambo's Avatar
I have one spare original USB cable. Just tested it with an original VCM and SDD. It works fine.
Old Aug 25, 2021 | 10:43 AM
  #28
^SiRtA^'s Avatar
Cool
Ok !
Old Aug 26, 2021 | 08:50 AM
^SiRtA^'s Avatar
Cambo, see pvt mex
Thankyou
Old Aug 26, 2021 | 09:25 AM
  #30
jazzwineman's Avatar
Cambo, see pvt mex
Thankyou
I agree with clubairth1 and think your original problem was a power issue. If you did not have the proper power maintenance on the battery when doing the reprogramming, this is what happens. Why were you reprogramming the TCM at all or was this some pure side effect of what you were programming?
Tom in Dallas/Plano
Old Aug 26, 2021 | 10:08 AM
  #31
^SiRtA^'s Avatar
Tom in Dallas/Plano
Hi !
Yes side effect, i've configured CCM (not reprogramming, sorry ) but during updating VID (automatic operagion... sob!!), the tcm produced the error p0610 (reprogram tcm module).
I've used a mongoose interface (not good for this car, infact i can't reprogram tcm). Now i've bought a VCM original (genuine) made in USA 078, but i need cables.
I'm waiting cambo to accordance about usb cable.
Old Aug 26, 2021 | 10:47 AM
  #32
Hi !
Why were you reprogramming the ECU/CCM in the first place? I would doubt there were any updates on the car that you did not already have.I have done some reprogramming and updates on a number of S-types and XF cars and never ran into that problem and using a cloned mongoose cable. scottjh9 has had some interesting experience when his laptop went off in the middle of his programming. You might write him and see if you can recover the way he did.
TBB
Old Aug 26, 2021 | 11:29 AM
  #33
^SiRtA^'s Avatar
TBB
Ok, I'll try to contact him. Anyway I tried to reprogram the TCM and ECM module ... (with power supply, super charged battery etc ..) Apparently it reprograms, but the error remains! I don't trust the mongoose cable, I think the only solution is VCM. 10 years ago I had the same problem, with the VCM I solved it by reprogramming TCM.
Old Aug 27, 2021 | 08:56 AM
  #34
abonano's Avatar
You need to reflash the TCM.
If I didn't mention before, reflash the ECM, then the TCM in that order with a 50 amp ripple free power supply on battery with windows down and all doors closed and trunk also!
Old Aug 27, 2021 | 10:20 AM
  #35
^SiRtA^'s Avatar
Ok, i have this power supply. I try to reflash ecm and tcm with your indications... but i have a question, can i use mongoose? With existent module ids option?
Old Aug 27, 2021 | 10:28 AM
  #36
Just use the mongoose and see if can see what is going on with the car. If it identifies you model and Vin on ts own that tells you it is probably working. I would walk around your IDS a touch with the cable attached and see how it reads running date. If that seems fine- run on with it.
TBB
TBB
Old Aug 27, 2021 | 11:01 AM
  #37
scottjh9's Avatar
if you start a new sdd session and it looks wonky, go to a previous session where all is ok and start your programming....that is what i had to do when i lost laptop power in the middle of a tcm reflash....a new session would not recover because the sdd would not recognize half programmed modules ....the older good session worked perfect
Old Aug 28, 2021 | 01:59 AM
  #38
^SiRtA^'s Avatar
Red face
To restore the correct data without the old session, you need to manually enter the VIN. The IDS has all the useful information about my car. Mongoose cable, correctly identified my VIN, prior to this problem. Now it doesn't identify the VIN. I think the correct operation is reflash ECM, TCM (option in IDS is reflash existent module? New module or special operations?). I have not tried the operation with the doors closed, the windows down, the hood closed.
Old Aug 28, 2021 | 02:48 AM
  #39
^SiRtA^'s Avatar
This is my software/hardware situation.
My Mongoose version.
Old Aug 28, 2021 | 07:02 AM
  #40
^SiRtA^'s Avatar
Ok bro, i tryed to reflash ecm from existing modules... see image !
If i go in the configure existant module, ecm, this is an error i see and i can't reprogram ecm..
