Just Purchased a 2002 S-Type Sport, have a few questions...
Old Aug 2, 2012 | 04:05 PM
daboss085's Avatar
Default Just Purchased a 2002 S-Type Sport, have a few questions...
I just bought a 02 S-Type Sport In seafrost green with tan and black interior, looks beautiful. I have a few questions....
How many quarts of oil does it take? and would you do synthetic?
and trunk does not seem to open in the interior, nor on the switch on the lid. Only the Key remote pops it open.
Thank you guys!
Old Aug 2, 2012 | 04:24 PM
Have you checked the valet switch in the glove compartment?
Old Aug 2, 2012 | 04:39 PM
JagV8's Avatar
The oil depends on the engine which you didn't specify. Qty is in the handbook I think but failing that JTIS.
Old Aug 3, 2012 | 04:00 PM
daboss085's Avatar
thanks, it was the switch and now the trunk does open
Could you give me a hand on the glovebox issue... When I open it, it falls to the ground. any ideas if theres a latch or something? thanks.
Old Aug 3, 2012 | 04:31 PM
weldboy's Avatar
There should be a little cable or string that attaches on the left outside of the box.
Old Aug 3, 2012 | 06:44 PM
daboss085's Avatar
I will check on that, and if there isn't anything there, then can it be purchased separate?
Old Aug 3, 2012 | 06:58 PM
daboss085's Avatar
Just wanted to know if one of you guys can help me. I experienced a leak today while it was raining in the center console area on the top where the sunroof switch console is. It looks like either the sunroof has a bad seal, the the windshield rubber is bad. The headliner is a bit wet it that area and the drip is coming straight through the light area by the sunroof switch, and leaks right into the j-gate! Anyone experienced this issue before?
Old Aug 3, 2012 | 07:07 PM
Mikey's Avatar
Probably the drain tubes from the sunroof area are blocked or disconnected. I think was a common issue on the pre-face lift cars.
Old Aug 3, 2012 | 07:21 PM
daboss085's Avatar
hey mikey, thanks for the info.... how can i look into that and fix the issue? My passenger side carpet under the dash is soaked as well....
Old Aug 3, 2012 | 08:05 PM
Mikey's Avatar
'Search' and ye shall find!
aholbro1
Dec 29, 2024 06:46 PM
Dicque
Sep 19, 2015 12:53 PM
colinc1444
Sep 14, 2015 07:54 PM
deanh
Sep 6, 2015 08:20 PM
Numwen
Sep 6, 2015 12:30 AM
