Key fob problem
Old Jul 7, 2013 | 12:46 PM
devo357's Avatar
Default Key fob problem
Good morning gentleman,
My Key fob does not unlock the doors it will lock but no unlock.
I changed the battery but still no unlock.
Do I need a new FOB? I really hope its not I have been reading alot of post about the cost and it sounds like a real hassle.
Dean
Old Jul 7, 2013 | 12:52 PM
JagV8's Avatar
Dirty or failing microswitch probably. What about the other fob? All the cars came with a minimum of 2.
Old Jul 7, 2013 | 02:03 PM
Bad Cattitude's Avatar
+1 Disassemble and clean contacts.
Old Jul 7, 2013 | 03:24 PM
sprdav33's Avatar
I had the same problem. Cleaning the micro switches fixed it.
Old Jul 8, 2013 | 11:57 AM
WhiteXKR's Avatar
If you have a failed switch, they are available on ebay pretty cheap: 3X New Switch Click Button Repair Remote Key Fob Jaguar s Type XJ8 XJR XJ XK S | eBay
Your local electronics repair shop should easily be able to replace this.
Old Jul 8, 2013 | 01:44 PM
devo357's Avatar
Thanks guys! what do you use to clean the micro switch???
Jagv8 mine only came with 1 switchblade key thats it! I bought it used.
Old Jul 8, 2013 | 01:49 PM
WhiteXKR's Avatar
Rubbing alcohol will due the job, but commercial aerosol contact cleaner from Radio Shack or Home Depot usually has a lubricant which might extend the life in addition to cleaning.
Old Jul 8, 2013 | 02:32 PM
tbird6's Avatar
I would plan on getting a second key and FOB. You are at risk with only one set. You can get them on EBay for a decent price and then the dealer usually needs to program it. Don't get the key or FOB from dealer. Just too high in price.
Old Jul 8, 2013 | 03:46 PM
I bought two fobs and one key on ebay.
The dealer couldn't get the key to programme, so I got another from them and returned the first one, the dealer key was actually much cheaper than the internet one.
It pays to check.
Old Jul 8, 2013 | 04:26 PM
devo357's Avatar
Thanks guys my eyesight is getting so bad it was hard to see it just to change the battery! lol
I will have to get my readers on and see if I can clean it out good. I have been looking on Ebay for a extra FOB and key and looked up most of the post's for replacements, any way to distinguish a factory key from a knockoff?
Dean
Old Jul 10, 2013 | 02:51 PM
Best bet is to check the seller's feedback. If all you see is people complaining about getting garbage fobs, find another seller. Here is the guy I used and had no problems...
eBay My World - remoteoverstock
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Rick Michael
Sep 6, 2015 06:53 PM
My Pham
Sep 4, 2015 03:37 PM
