knock sensor malfunction p0330 s type 4.0
Old Jul 11, 2016 | 09:21 PM
payroll416's Avatar
Entered vin and I see build date 23-11-2001 but it doesn't specify unless im missing something. Pretty sure its a pre 2002.5 my tho.
Old Jul 13, 2016 | 05:44 AM
JagV8's Avatar
A 4.0 is pre-X
I think X is better called redesign but use facelift you like. Though there's a facelift in 2004 which changed a lot less than the redesign.
I like redesign because they changed so many many things (5-spd auto -> 6 spd ZF, 4.0 -> 4.2, major suspension overhaul, Brembo discs, CAN bus, etc etc).
Old Jul 13, 2016 | 05:50 AM
JagV8's Avatar
Originally Posted by Datsports
Didn't know deaths were related to diesel !
Here it's a huge problem. Also France, Spain, China, India and many others.
Some cities have had to restrict cars e.g. only allowing them on alternate days (such as odd numbered on one day, even numbered the next).
London is estimated to have many thousands of extra deaths per year due to diesel pollution. (UK government is being sued for failing to address it, too.)
hmm, not really the subject of this thread though...
Old Jun 14, 2017 | 07:45 AM
payroll416's Avatar
May finally change the knock sensors this week . Can i reuse the intake manifold gaskets or should i order 8 of em? They're $20 each (look like rings ) I believe.
Old Jun 21, 2017 | 12:16 AM
payroll416's Avatar
Your on to it . It's our passengers side way down here .
Look across your engine , bank 1 is always slightly more forward than bank 2 .
It will be self explanatory when you pull the plastic cover off and remove your t/b as to how to remove the manafold ,
You'll find a row each side of about 8 screws .
Maybe pre order your gaskits and
Knock sensers , be aware that your earlier sensers may look differant to mine and may thread in to the block rather than bolt down as mine do .
would these work? it beats $160 for 8 at dealer
Amazon Amazon
Old Jun 21, 2017 | 05:12 AM
Datsports's Avatar
https://www.amazon.ca/Victor-Reinz-M...ype=automotive
it does say they are correct for your model .
worth a try .
rodders1marsbar
Apr 19, 2016 07:03 AM
MannyJag
Apr 19, 2016 06:53 AM
MannyJag
Apr 18, 2016 10:17 PM
MannyJag
Apr 18, 2016 10:15 PM
Jpav27
Apr 17, 2016 02:22 PM
