Leaking Trans Mount?
Old Mar 16, 2020 | 10:26 AM
DigitalDisaster's Avatar
Default Leaking Trans Mount?
My wife's 50K mile 07 STR suddenly has a small pool of light oil under the trans area when it hasn't been driven for several days. The source appears to be the trans mount - I'm assuming it's fluid-filled. It looks like it wouldn't be that difficult to replace (bolted on) - anyone here done it? I found a new one online for $156.
Thanks,
Old Mar 16, 2020 | 12:34 PM
abonano's Avatar
Thanks,
Just did this yesterday on my 04 XJR.
Yes, the originals are filled with a hydraulic oil and mine was leaking. Had a sheen on the cross member.
Not that bad if you have a lift. Could be a bit of a pickle doing it on ramps and jacks.
The trans must be supported across the plastic pan.
The cross member must be removed to access the top bolt holding the mount in place.
Made a huge difference after installing.
Old Mar 16, 2020 | 02:55 PM
Thanks for the reply. I was going to place a 2 x 4 under the plastic trans pan and use a jack to hold it. Is the pan strong enough to support the weight?
Old Mar 16, 2020 | 09:52 PM
abonano's Avatar
Yes, all you really need to do is lift it up to the pan to take the weight off the two bolts from the rear of the trans to the mount.
When Reinstalling leave some wiggle room with the cross member and line up the trans to the new mount.
Old Mar 17, 2020 | 10:26 AM
Awesome, thank you for your input.
Bob
Old Mar 17, 2020 | 11:36 AM
abonano's Avatar
Bob
Anytime.
Old Mar 20, 2020 | 03:12 PM
This was a real easy job - about 45 minutes in total. Glad I didn't pay my mechanic to do this
944xjs
Apr 13, 2019 12:29 PM
catbug12
Mar 6, 2016 11:21 AM
Jim Dunne
Sep 25, 2013 01:47 PM
ukester
Jul 11, 2013 05:01 PM
Keith M
XJ40 ( XJ81 )
Oct 24, 2011 06:37 PM
