Lock
Old Mar 27, 2025 | 01:14 AM
Frank koper's Avatar
Default Lock
The locks on the doors open and closed by the remote so thats working
When i drive automatic the door lock
Now my problem , when i stop at the driver side i can open the door all other doors stay closed locked. Only if i unlocked the door then it can be opened
How to remove this setting? Ore so that the doors can be opened standing stil
Old Mar 28, 2025 | 11:51 PM
Peter_of_Australia's Avatar
I read your question already two days ago. Since then I am permanently checking, if someone has an answer for you...
...because I have similar problems like:
1. Auto-lock of all door as soon as the car moves. (on one of my S-Types, not on the other one, where this nonsense coincidentally stopped after a professional locksmith programmed
the S-Type to recognize 2 more remotes).
2. Again something, which one S-Type of mine does, the other does not: After unlocking the car and opening the door the driver's seat drives backwards,
which annoys my wife, as this means that she cannot put her bag behind the driver's seat, as it would get squashed.
In my opinion my "Problem 1" and my "Problem 2", just like your problem, are things, which can be rectified by connecting a forbiddingly expensive "computer programming device"
to the S-Type, operated by a professional, who knows, what he is doing and setting all those various parameters/settings as required by the customer.
The problem I have with that solution is, that the next shop, which may be possibly be able to do this is either 180km or 320km away from where I live, plus it would be forbiddingly expensive.
Hence, I cannot see a solution other than living with the settings an S-Type has.
But if someone out there knows a simple or non-expensive way (i.e. which device from a cheap online seller can do it?), I would like to hear about it...
Old Mar 29, 2025 | 05:22 AM
User 42324's Avatar
I believe auto-locking (on drive away) can be disabled through IDS/SDD. If your door isn't locking/stays locked I suggest it's the door lock.
As my car has driver memory on the seat & moves back to make more room, i suggest putting the knob in manual adjust before removing the ignition key & it'll stay put. Your wife can then put her bag behind, get in the car & press her memory setting (or turn the knob to auto & press it.
Old Mar 29, 2025 | 07:46 AM
User 42324's Avatar
Re-read your post. Your car's probably set to unlock just the driver's door with one press & all doors with two presses. This can be altered with a button pressing sequence on the fob to one press unlocks all. A search should turn up the procedure.
Old Mar 31, 2025 | 06:42 AM
Encouraged by USER 42324's idea that there might be something / some knob to rectify my "dancing seat" issue, when I open the door, I searched the net again, coming across keywords like "seat convenience mode", and I finally found the answer: There is a round knob on the left of the steering column (so, pretty low on the dashboard) and there are the options "auto" and "column". I changed it from "auto" to "column', which ended the never ending "seat dance-party". Great - one problem less - an important one, because while my wife loves that S-Type, she hates the musical-chair dance every time she want to enter the car...
I just whish there would be equally easy solutions for the auto-door-locking issues.
But for all I know that can sadly only be modified by a specialist with an expensive device (computer), who will charge an arm and a leg for this little modification...
Old Mar 31, 2025 | 02:53 PM
User 42324's Avatar
Originally Posted by Peter_of_Australia
Encouraged by USER 42324's idea that there might be something / some knob to rectify my "dancing seat" issue, when I open the door, I searched the net again, coming across keywords like "seat convenience mode", and In finally found the answer: There is a round knob on the left of the steering column (so, pretty low on the dashboard) and there are the options "auto" and "column". I changed it from "auto" to "column', which ended the never ending "seat dance-party"
Glad to help. I would've been clearer about the control knob switching between auto adjustment (memory settings) & manual. I assumed you knew about it as you have memory seats. My mistake.
Old Mar 31, 2025 | 04:57 PM
Yea... - no. I did not know about that "switch over to manual knob" (where "manual" is called "column", which does not make it any easier), which is why I did not know how to stop the musical chair party each time you open the door... But not it's all good. Thanks.
I only just told my wife about the good news (I fixed it last night and it is morning here now). After I told her she initially slapped herself a few times first making sure she is not dreaming (but awake already), and then I had to tell her another 2 times... She said, I "made her month" (not just day)...
I really do not know, what Jaguar was thinking, when they added that feature: It's highly annoying and it is eating up the battery...
Old Apr 1, 2025 | 02:13 PM
User 42324's Avatar
Technically it's a manual adjustment knob - mine also has adjustable pedals (specced with that but not front parking sensors, go figure). Get your seat, steering wheel, pedals & mirrors how you like them & save them as a memory setting. Switch to auto & press a 'mem' button to restore your settings. You know the column adjusts in & out as well as up & down, right ?
I believe the mem settings restored by the car can be keyfob dependant too. Haven't tried as it's just me that drives it.
EDIT:- Added an s to mirrors.
Old Apr 1, 2025 | 09:04 PM
Yes, thanks, I knew about the memory setting of mirrors and seat (mem & 1 or 2), and I knew also about that button left of the steering wheel to adjust the column (but I never used it, as the column was just right). I just did not know about the auto-feature-switch-off as described above...
Doomer
Jan 19, 2026 10:34 AM
KNARF
Europe
Sep 25, 2024 04:20 AM
Estilian
Jul 1, 2013 12:14 PM
Harryk
Mar 2, 2012 04:29 PM
Igloo112
Oct 18, 2008 10:37 AM
