magnaflow upgrade engine codes
Old Oct 23, 2011 | 07:23 PM
sivkov-y's Avatar
Default magnaflow upgrade engine codes
I would like to know from all of the dudes that have high flow cats installed on the jags. Did any of you receive any codes related to catalyst inefeciency or under voltage, and what was done to fix the problem. Also I never did do a hard reset after install, I would like to know if its a necessary procedure to do after high flow cats are installed. Thanks.
Old Oct 23, 2011 | 07:27 PM
bfsgross's Avatar
sivkov, no codes. Def. do a hard re-set after the install.
Old Oct 24, 2011 | 12:23 AM
sivkov-y's Avatar
I have catalyst related codes, I know how to fix, was just wondering if any one with high flow cats had any codes.
Old Oct 24, 2011 | 03:48 PM
bfsgross's Avatar
I had a code that was corrected by a hard re-set.
Old Oct 27, 2011 | 04:55 AM
sivkov-y's Avatar
I did a hard reset and so far no codes have come up.
Old Oct 27, 2011 | 05:58 AM
1320racer's Avatar
I have 200 cell high flow cats and have had no codes after running them for a couple months. Be careful though as there are big differences in quality and performance in aftermarket cats.
Most (not all) OEM cats have approximately 300 cells per inch.
Most (not all) high flow cats are 200 cells per inch.
Racing cats typically have 100 cells per inch and cause codes for many vehicles.
I searched a lot on Porsche bulletin boards for enthusiast that live in CA before I purchased my hf cats. I did not try 100 cell race cats because they seemed to cause too much hassle for too many people.
Give the race cats a try and report back if they work well for you.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
D.K
Dec 10, 2023 02:05 AM
scottatl
Sep 4, 2015 08:08 PM
OkieTim
Sep 2, 2015 12:48 PM
