Major melt down... Rear end clunking
Old Dec 24, 2011 | 02:05 PM
qwiketz's Avatar
Default Major melt down... Rear end clunking
Well... Last night we came home and parked the car in front of the house. Prior to that there were no odd sounds and we definitely weren't beating on it. When I moved the car about 50 feet, I started hearing a clunking sound. At first I thought I ran over a nail and a tire went flat.
This morning I inspected and all the tires are good. I backed up the car 20 feet and didn't hear anything. I drove it forward at about 3-5 mph and heard the sound. When we did it a second time, same deal. No sound backing up. Going forward there was a bad metal breaking thud. It got progressively louder as I pulled back into the spot.
Well, the car is going to sit until I can get it flat bedded to the shop. The sound is definitely coming from the back of the car. The engine is running fine and there aren't any obvious things bumping such as the exhaust... What do you guys think? If I had to guess it sounds serious like rear end gears or axle but who knows...
Old Dec 24, 2011 | 03:23 PM
bfsgross's Avatar
Sorry for this mystery issue to pop up during the holiday. May be rear-end. Damaged differential components may have settled after parking her? Hoping all is well.
Old Dec 26, 2011 | 08:30 AM
Mafioso's Avatar
recently I had a similar noise, and it turned out to be the input shaft dust cover on the diff.
I hope that helps.
Old Dec 26, 2011 | 06:20 PM
qwiketz's Avatar
hell yeah, that helps alot! So what exactly happened in your case? How did you fix it. I"m not afraid to get the car in the air and screw with it if it's an easy fix. If not, I'll have it flat bedded to the shop.
Give me a ring do discuss if you'd like. I'm out west so I'll be up for quite a while- 714-404-8410
Old Dec 27, 2011 | 04:28 PM
qwiketz's Avatar
Anyone have the link to the repair manual for this car? I had it on my desk top but that crashed a while back. I'll need to get more info on the dust shield.
Thanks!
Old Dec 27, 2011 | 08:20 PM
bfsgross's Avatar
Shoot, a dust shield would be a ton better than a diff. Hope it all pans out in your favor.
Old Dec 28, 2011 | 07:54 AM
clubairth1's Avatar
Community Influencer
Thanks for that but I can't find any dust cover anywhere??
Here is the rear diff.
Old Dec 28, 2011 | 06:08 PM
qwiketz's Avatar
I'm going to see if I can get under the car after work. I'll let you know what I'm able to find...
Old Dec 30, 2011 | 07:07 PM
qwiketz's Avatar
Alright guys. Here is an update. The car definitely not drivable. When in drive or reverse the car doesn't move. I got it towed to the shop but they're not going to get it until Tuesday.
Shortly after loading the car on the flatbed, I found a really good sized bolt on the ground. It was totally sheared off at the threads. The flatbed didn't drive over the spot so I'm thinking it's doubtful it fell off the truck. I'm not sure what this would be off of, due to the size, but who knows. The head of it looked to be at least 3/4" and the shaft that sheered off looked to be at least 3/8 or 1/2". The length before the part that sheered off was at least 2 1/2". Anyone have any ideas?
Old Dec 30, 2011 | 07:10 PM
qwiketz's Avatar
Btw, the bolt looked more like 7 or 8 rather than 14.
Old Dec 30, 2011 | 08:25 PM
bfsgross's Avatar
I bet the rear of driveshaft coupling sheared off or bolts took off?
Old Dec 31, 2011 | 04:27 AM
JagV8's Avatar
Maybe a bolt from the side of the trans. where the shifter cable goes in? They're known for working loose, rather than shearing, though. Any chance of more accurate dimensions?
Old Dec 31, 2011 | 07:39 PM
qwiketz's Avatar
Bolt from where the trans shifter cable? I don't know. This one i saw was pretty hefty. In addition, the car would go into gear fine, it just wouldn't move. It seems like it's a diff or axle. When I put the car in drive, it won't even move on it's own. It's like the car is loading agianst the rear, whether in reverse or drive.
btw, this sucks and will probably cost me a fortune!
Old Jan 3, 2012 | 07:25 PM
qwiketz's Avatar
Hi guys. So here's an update. I called the shop and they said that there are 6 bolts somewhere in the driveline (it seemed like on the drive shaft assembly) that hold things in place.
Well, on my car we were down to 3 bolts before I sheared off the 4th bolt that I found when the flat bed picked me up. They said it's not too bad to replace, but they're waiting for the bolts from the jag dealer.
The shop said that the car that worked on my car a while back for my accident didn't tighten them enough. They said that they've never seen this happen before. He also said I was about 20 miles away from this getting really expensive or dangerous.
I called the body shop and they're headed to the repair shop in the morning. I'm curious to see how this one pans out. I got the car out of the body shop in June.
Old Jan 17, 2012 | 01:44 PM
qwiketz's Avatar
As an update it was caused by re-used lock nuts on the driveshaft. How lame to not just replace the nuts with new ones since they're $2-$3 each... That problem is now solved and fixed by the idiots at the body shop.
Old Jan 17, 2012 | 02:46 PM
Well that was a stupid mistake but at least it was an easy fix.
Could have been much worse if the shaft had got free!
Old Jan 17, 2012 | 03:24 PM
Jon89's Avatar
Always glad to read about fixes that turn out to cost just pocket change, especially when some ill-informed or careless moron was responsible for the issue in the first place. This one could have turned into a hugely expensive disaster. Good to hear that you're confident it has been resolved, but I would never trust that body shop again....
Old Jan 18, 2012 | 01:09 PM
qwiketz's Avatar
Yeah, the shop said I was really close to a $10k accident if not fatal if I was in the freeway. If the drive shaft got loose it could have taken out the rear end and seriously damaged the car or potentially shot into the car like a pole vault. Neither would have been good.
Thang Nguyen
Oct 12, 2015 01:25 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
XKR-NC
Sep 4, 2015 08:23 AM
obwoodie
Sep 3, 2015 07:45 PM
