Misfire ?
Old Jan 21, 2012 | 09:04 AM
police666's Avatar
Default Misfire ?
If i have a misfiire will i have any warnings on the dash ?
Old Jan 21, 2012 | 09:21 AM
clubairth1's Avatar
Community Influencer
Depends on how bad they are. We need to understand that even a perfectly running engine will and does have random misfires. This does not mean anything until they rise to the level determined by Jaguar as a problem.
So you might get no check engine light. You might get a check engine light. And worse of all you might get a flashing check engine light which is telling you the cats are in danger of being damaged or destroyed if you keep driving.
It also not unusual to scan for codes and find some misfire codes but the engine has been running just fine. The engine monitoring software is very precise these days. The next step is automatic reporting to the government when you car has an emissions problem. This will happen in the next several years as the OBD laws are tightened around our necks further.
Old Jan 21, 2012 | 09:36 AM
police666's Avatar
the reason i ask is i heard a bit of a "poping" comming from (i think) the right exhaust when i gave it a bit of a wot in park, it drives fine and i couldn't hear it at wot when driving.
Old Jan 21, 2012 | 09:44 AM
bfsgross's Avatar
Do you hear any exhaust leaking under the hood near the EGR or thereafter prior to the passenger side cat?
Old Jan 21, 2012 | 09:45 AM
clubairth1's Avatar
If it's good under WOT then most likely everything is working properly. I have noticed a bit of popping when doing that to but can't really say why?
Depending on RPM maybe running into the rev limiter?
Old Jan 21, 2012 | 09:54 AM
police666's Avatar
No exhaust leaks,
it wasn't hitting the rev limiter, it was under 3000rpm
it was just a coupple of pops and only under wot, the doesn't seem to be any isues when driving and will still spin its wheels form standstill in the dry.
I only noticed it cos i had the door open and was parked next to a wall, maybe it's always done it and i''ve never noticed.
If i buy a obd scan tool from ebay for about £15-£20 will i be able to use that with the AutoEnginuity software ?
Old Jan 21, 2012 | 10:08 AM
JagV8's Avatar
No. AE supplies a special "lead". (Most "leads" include a microcontroller internally.)
Old Jan 21, 2012 | 10:26 AM
police666's Avatar
thanks jagv8 the reason i asked is a "friend" says he can get me a copy, we'll see.
What hardware and software would you recomend for someone who has never used obd scan tools.
Old Jan 21, 2012 | 10:49 AM
JagV8's Avatar
You can freely download their software from their site. No special effort needed.
It's no use without their lead and an activation code specific to your lead.
How much do you want to spend, maximum? Also, do you have a laptop running Mickeysoft windoze?
edit: or a smartphone? (but result will be not as good as a laptop)
Old Jan 21, 2012 | 11:00 AM
police666's Avatar
Got a good laptop running Micro$oft Windows 7 x86 Ultimate.
Cos ive never used anything like it ease of use would be good, would £50ish buy anything useful ? or am i being optimistic ?
I'm still bankrupt from christmas so will prob be month or 2 before i buy
Old Jan 21, 2012 | 11:20 AM
03Xtype's Avatar
yes it will set a Check engine light
Old Jan 21, 2012 | 11:47 AM
JagV8's Avatar
You can get a USB elm327 from fleabay for about £10 and there's free software that's good enough for simple use.
They're so cheap because they sell so many.
Like even the ones costing £200 it'll only read the PCM. For the other modules you need such as AE but it's more like £300-400.
Old Jan 21, 2012 | 12:20 PM
police666's Avatar
ok, thanks V8, at £10 i might be able to get one sooner than i thought.
Old Jan 21, 2012 | 12:26 PM
police666's Avatar
Sorry if i'm dragging this on a bit
Would this one be ok ?
ELM327 Scanner Software USB Interface - Free Shipping
It doesn't list Jaguar in the compatability lists.
Old Jan 22, 2012 | 07:44 AM
JagV8's Avatar
The USB end looks odd but so long as it's actually OK it should be fine. OBD II is a standard (bit of a minimal one, but still) and mandated by laws so even Bentleys etc all have it.
Be careful not to flatten the battery. Shortish periods or start engine (or attach charger to car battery). OBD uses next to nothing but you need ign II so lot's on!
Old Jan 22, 2012 | 09:25 AM
police666's Avatar
ok, thanks.
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Norri
19
Sep 28, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
