misfiring while idle
Old Jan 1, 2012 | 09:42 PM
phaelax's Avatar
Default misfiring while idle
Car accelerates just fine, no codes show up, but when sitting idle it runs rough and I can hear the misfires. Plugs were changed within the last 10k miles or so, and for the most part the coils are all new (changed at different times). Could it be an issue with fuel injectors?
Old Jan 2, 2012 | 04:24 AM
JagV8's Avatar
Car info (see below)?
Old Jan 2, 2012 | 07:50 AM
Bacardi 151's Avatar
Plugs were just changed? My money's on him having a 2.7 turbo diesel...
Old Jan 2, 2012 | 09:47 AM
JagV8's Avatar
Nah - location is OH and there are no diesel jags there.
Old Jan 3, 2012 | 02:16 AM
phaelax's Avatar
I keep forgetting the info isn't in my sig anymore. '03 STR
Old Jan 3, 2012 | 06:10 AM
JagV8's Avatar
I suppose it COULD be the injectors, but there are plenty other suspects such as EGR, PCV, and of course the fairly common air leak between air box & engine. And others.
I'd look at OBD live data and check the core (i.e. central) sensors for plausibility, check it's running CL (closed loop), then look at the fuel trims - and of course any codes.
Bear in mind even the battery can cause issues if it's failing - not saying it is because my idea is to get more data rather than immediately spend $$$.
Old Jan 3, 2012 | 06:31 AM
carelm's Avatar
You might want to run a can of Techron or other brand of fuel injector cleaner through your fuel system. I had a similar problem with my Audi A6 and it cured the problem. Also, like JagV8 said, look for air leaks.
Old Jan 3, 2012 | 08:04 AM
I was being sarcastic; diesels don't have spark plugs...
Old Jan 3, 2012 | 08:41 AM
JagV8's Avatar
No but they have plugs
aode06
Jul 28, 2023 02:26 PM
workworkwork
Oct 23, 2015 10:26 AM
tomkilner
Oct 9, 2015 07:10 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
