My sick Cat
Old Jul 28, 2014 | 03:25 PM
TLass's Avatar
Default My sick Cat
Hi everyone, 1st post here and unfortunately its not a happy one. I'm in search of some advice.
I have a 2004 S Type V8 (4.2) 114K miles, recently had head gasket job done (July 20th), and now the shop can’t seem to get the "readiness" codes to reset. They asked me to drive it for 100 miles or so them bring back which I've done but still no reset on code. I’m going on day 4 now and approaching 300 miles of driving.
Today I decided to go by local Autozone and Advance auto to see what codes they came up with (they are as follows)
1. P1647 (says for Chrysler OEM brand)
2. P1000 (says for BMW OEM Brand)
3.P0128 (says engine Coolant Temp) or Check coolant level. (levels are fine but light on dash says low)
Any advice or anyone having to reset "readiness" codes please chime in. I can’t get car inspected without having these codes cleared.
Thanks in advance
TL
Old Jul 28, 2014 | 04:08 PM
motorcarman's Avatar
You need to get the correct guide for the DTCs
This one is for the 2003 MY X202 but it will have the same codes and explanations.
bob gauff
File Type: pdf
Old Jul 28, 2014 | 04:55 PM
Jon89's Avatar
What shop are you using? I'm in northwest Raleigh and I know most of the area shops....
Old Jul 29, 2014 | 07:50 AM
TLass's Avatar
Angry re sick cat
Thanks for the reply.
Jon 89 car is at Roland’s auto in Durham, located off Avondale drive. Please let me know of GOOD shop(s) in the area.
Today I've taken the car back to the shop to see if they can reset the codes. I have driven the car for over 300 miles and nothing seems to be happening.
So far I've racked up $3660.00 for this repair, and the check engine light is still on as well as the readiness codes still have not reset. Hopefully they'll get it right and I'll be back on the road soon.
Motorcarman thanks for that guide.
Old Jul 29, 2014 | 01:08 PM
tbird6's Avatar
Why were the head gaskets changed?
We don't see that very often and if you badly over heated the engine you might have additional problems.
Old Jul 29, 2014 | 02:35 PM
TLass's Avatar
Tbird6, I was told by the autoshop that it had classic signs of a headgasket problem (rough idle from cold crank, water dripping from tail pipe) they tried using a product called "blue devil" to "fix" it but that only made things worse. after driving the car for about 10 miles it did overheat and I pulled over right away to have the car towed back to the shop.
So I made the call to go ahead and change the gasket. it was comfirmed gasket was bad. I also had timing chain replaced.
Now the car's throwing all these codes. IDK.
Old Jul 29, 2014 | 03:02 PM
tbird6's Avatar
OK thanks for that but we just don't see the 4.2L lose head gaskets and we definitely don't see any timing chain problems because 2003 is when Jaguar updated and fixed all the earlier problems.
Just seems out of place for a 4.2L??
Sometimes it does take a good while for all the readiness monitors to set ready. It took me about a week of varying driving to get them all set. I tried to follow the drive cycle instructions but that did not help any.
Old Jul 29, 2014 | 03:25 PM
TLass's Avatar
Thanks tbird, there was no issue with timing chain, but i decided since motor was apart and I plan on keeping this cat around for a while it was good time to change it (there was some very little scratches in one of hte upper timing chan tensioner) I may have been over zealous on that call.
The shop is suppose to use "the drive cycle instructions" Seems like I shouldn't hold my breath on that working. thanks for bursting my bubble.. LOL. I'll keep you guys updated on the progress.
Thanks for the feeback.
Old Jul 30, 2014 | 06:54 AM
Jon89's Avatar
The best indie Jaguar shop in Durham is Flying Circus English Cars, phone (919) 596-4250. Why did you choose Roland's?
Old Jul 30, 2014 | 10:09 AM
TLass's Avatar
Thanks Jon89,
I went to Rolands, because of a friends recommendation (silly me). I have actually heard of and know where Flying Circus is. I was hoping to save money by going to Rolands Auto (again silly me). You get what you pay for.
Old Jun 13, 2022 | 01:21 PM
sickcat's Avatar
I live in Clayton NC, can you recommend a shop in Raleigh, Garner, Clayton area?
Old Jun 13, 2022 | 05:45 PM
This thread is 8 years old.
Old Jun 13, 2022 | 06:15 PM
sickcat's Avatar
so I'm assuming that's No.
Old Jun 14, 2022 | 07:36 AM
S-Type Owner's Avatar
You might want to try making an inquiry in your Regional forum, which is located here:
US Lower Atlantic - Jaguar Forums - Jaguar Enthusiasts Forum
tdc
Aug 15, 2016 01:56 PM
Dr. D
Sep 27, 2012 07:27 PM
Tony_Jagger
Nov 29, 2011 07:11 PM
