Need 2 (poss 4) original S-Type wheels
Old Mar 29, 2015 | 02:05 PM
ManoFlem's Avatar
Default Need 2 (poss 4) original S-Type wheels
Hi, Jag told me I have incorrect wheels on my rears. 275/40/18's. While my front are 245/40/18's. I understand they are XK wheels. Put on car before my time. Anybody out there have a set of 4 wheels in good condition they would like to off load or Part X. My ones are real nice set of Alloys, but I am getting ABS issues and wonder if this might be the root cause. I am based in SW London. Cheers.
Old Mar 29, 2015 | 02:57 PM
Mikey's Avatar
You've quoted tire and not wheel size. All four tires must be the same size to avoid ABS issues.
Old Mar 29, 2015 | 03:13 PM
JagV8's Avatar
Those sizes are miles wrong!
I have an STR and it has correct wheels+tyres:
rear 275/35R18, front 245/40R18
(these would be bad rears to fit to a car with half the HP i.e. a 3.0)
If you use a tyre size calculator you'll see my wheels end up almost identical rolling diameter. Yours are way out.
Be sure to tell your insurers you have a modified car until you sort it out or you may well be uninsured!
Old Mar 30, 2015 | 04:47 AM
ManoFlem's Avatar
Jag said my front 245/40/18's are correct. I only need 2 of the same to get the car back to normal. Any web links? where I can buy, Ebay etc? I am based in SW London. PS: The alloys I have on now appear to be a nice flash set but I just want to get the originals back on and cure and reduce the problems I am having. Main problem is LIMP HOME MODE. Engine Fault, Park Break error, DSC ERROR. And a christmas tree dash.
Old Mar 30, 2015 | 04:49 AM
ManoFlem's Avatar
So the wheels I have are eith XK wheels or S-Type R wheels. I take it thats what STR is ?? :-) ... Im learning as I go here. ;-)
Old Mar 30, 2015 | 09:11 AM
Mikey's Avatar
You need two new tires of the same size. Any tire shop will have them.
Old Mar 30, 2015 | 09:57 AM
JagV8's Avatar
Well... maybe or maybe not - depends which rims (wheels) they are. Most have the wrong offset and many the wrong width.
Old Mar 30, 2015 | 10:01 AM
Mikey's Avatar
True, but that would give a different set of issues not mentioned by the OP. All we know is that the rear tire size is incorrect giving a speed differential with the front which might be contributing to ABS issues.
Old Apr 7, 2015 | 09:41 PM
Warspite's Avatar
Is there an equivalent of Craigslist in the UK? A place of part outs, from wrecks?
Old Apr 7, 2015 | 09:57 PM
Cambo's Avatar
If you can post a picture of the wheels you have on your car, it would be easier to figure out which ones you have, and which ones you need.
In any case I doubt that oversized tyres on the rear are contributing to the "LIMP HOME MODE. Engine Fault, Park Break error, DSC ERROR. And a christmas tree dash." that sounds more like a bad battery to me...
Old Apr 7, 2015 | 11:14 PM
plums's Avatar
No, there are wheels and there are tires.
What you need regardless of wheel size, is a wheel and tire combination that turn
the same number of revolutions per mile front and rear.
Actually having the numbers would have been sensible far earlier in the thread.
Here are the numbers:
245/40/18: 784.6
275/40/18: 756.8
Tire Size Calculator
If you put 245/40/18 tires on the rear wheels, the
front and rear speed sensors will see that same rate of revolution.
The easiest way to find out if the theory that the different tires are causing
a problem is to borrow two 245/40/18 tires on wheels and mount them on
the rear. If the problem persists, fix it while the 245/40/18 are still on the
car. If the problem clears, then put 245/40/18 tires on the existing rear
wheels.
Old Apr 8, 2015 | 01:13 AM
JagV8's Avatar
True but what width are his rear wheels (rims for the USA)? They may be too wide for 245 tyres (tires).
Yes there are rough equivalents of craigslist but in any case scrap yards (wreckers) will have what he wants.
Old Apr 8, 2015 | 01:37 AM
plums's Avatar
Unless the rear wheels are wider than 9 inches, that is doubtful.
Any spec sheets for the 245's found at tirerack.com will give the
nominal rating wheel width, and the permissible wheel widths.
Jaguar tends to size tires at the minimum wheel width for
any given size. Sub-optimal, but that's what they do.
Old Apr 8, 2015 | 02:17 AM
Cambo's Avatar
If they are actually XK wheels then they will be 8.5" front and 9.5" rears.
But we don't know which wheels until we see some pictures.
Old Apr 8, 2015 | 08:55 AM
pab's Avatar
pab
I've posted this other places, but it might be relevant here...
Any of the wheels listed below will fit your car provided you don't select a smaller wheel (e.g, 16") and have large brake rotors.
Jaguar - Vehicle Bolt Pattern Reference
(Jaguar _ Vehicle Bolt Pattern Reference)
On these pages you can find Jaguar vehicles Bolt Pattern and Offset. This will help you in determining High or Low offset and bolt patterns of your vehicle.
YEAR MAKE MODEL COMMENTS
2000 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2001 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
Understeer is when you hit the wall with the front of the car
Oversteer is when you hit the wall with the rear of the car
Horsepower is how fast you hit the wall, and
Torque is how far you take the wall with you
Old Apr 8, 2015 | 05:19 PM
ManoFlem's Avatar
Thanks for the comments guys. First of all the battery is less than a year old, and has been checked. The rear wheels are clearly wider than the fronts. Am I right in saying 245 is 245mm? In that case the WHEELS (NOT TYRES) are 275mm. So I need smaller wheels. Not tyres.
Old Apr 8, 2015 | 05:21 PM
ManoFlem's Avatar
Does the 2002 S-Type come with the same size wheels all round? As standard?
Old Apr 8, 2015 | 05:24 PM
Cambo's Avatar
S-Type R models have "staggered" wheels & tyres i.e. wider at the back than the front, the other S-Type models have the same size wheel all round.
Tyre width is measured in mm e.g. 245, but the wheel width is measure in inches e.g. 8", 8.5", etc...
If you just post a picture of the wheels currently on your car it will be extrememly easy to give you some proper advicre, until then it's all just noise...
Take a photo of the front wheel, and the back wheel, post it up here.
Old Apr 8, 2015 | 05:31 PM
JagV8's Avatar
Ignoring the STR, which is not the car in question, I think all came with front & rear the same (wheels aka rims as well as tyres aka tires). 245 is mm and is a tyre width here.
The suspension will be stressed in ways not designed if the rears are 275mm tyres (I'm assuming on suitable i.e. wider wheels than the car was made for).
Just buy 2 more of the proper wheels & tyres for the rear. You may be able to sell the current rears for more money and make a profit.
I dread to think whether the car is even roadworthy under English law but don't find out - just get rid of those wrong wheels!
Old Apr 8, 2015 | 06:50 PM
Mikey's Avatar
That's the width of the TIRE, not the wheel.
