New cooling fan
Old Jul 31, 2018 | 10:26 AM
W Young's Avatar
Default New cooling fan
Need to find switched 12V source to power new fan. Help?
Old Jul 31, 2018 | 03:59 PM
NBCat's Avatar
What vehicle? What MY? Why is this being done?
Old Jul 31, 2018 | 04:05 PM
W Young's Avatar
2001 S-type 4.0 - replaced original non-working fan with OEM fan, after replacing fan relay on original with no results. Need to wire into switched 12V to power new fan.
Old Jul 31, 2018 | 04:10 PM
NBCat's Avatar
Use search function on this forum and read about wiring issue behind front bumper. You cannot just run a wire as the radiator fan is controlled by the ECM.
Use the Electrical Guide to troubleshoot the issue:
http://www.jagrepair.com/images/Auto...x2022001en.pdf
Old Jul 31, 2018 | 04:20 PM
W Young's Avatar
Thanks for the info, the wiring manual will be handy!. Understand original fan has to be controlled by ECM and relay. Removed original assembly and replaced fan assembly with a 12V, 16" fan that runs on 12V without all the other stuff. All is installed and fits perfectly. Just have to find a switched 12V source to tap to run the fan.
Regards,
Wayne
Old May 15, 2019 | 10:40 AM
BlackKat's Avatar
Hello Wayne,
How did it go with your fan mod? Also, what fan did you buy?
The 2nd speed for AC on my fan is no longer working as it should and having a hard justifying $700 for a new fan.
04 XJR
Old May 15, 2019 | 02:06 PM
W Young's Avatar
Sorry but I replaced the radiator cooling fan, not the AC fan.
Old May 15, 2019 | 03:08 PM
kr98664's Avatar
04 XJR
Looks like you may be in the wrong forum, if asking about an XJR.
FWIW, when the fan quit on my '02 S-type, the only available replacement was the entire motor/blade/shroud assembly. The motor was not available separately, at least new. The armature was chewed up on my old motor, but I found a good used motor on eBay. The brushes on that motor were worn about 2/3 of the way down. I found some universal brushes of the same original size and replaced them. That was several years ago and this used motor is performing flawlessly. The used motor and new brushes were only about $75 at the time.
Old May 15, 2019 | 04:24 PM
BlackKat's Avatar
Yes Wayne, I'm referring to the radiator fan. Sorry about the confusion; the radiator fan cools the A/C condenser as well which is why I'm interested in your replacement. My radiator fan seems to have gotten lazy.
How did it go with your radiator fan mod? What radiator fan did you buy? How did you hook it up etc.
Yes kr98664, I'm definitely in the wrong forum, however the info from Wayne's universal fan install will greatly help for research in case I decided to follow route. Not much luck to this question on the X350 forum.
Glad to hear about your rebuild. Good stuff! Do you happen to have a write up or photos? Where did you source your brushes?
Many thanks.
Old May 15, 2019 | 08:13 PM
kr98664's Avatar
No photos, sorry. I do remember the nut securing the fan blade had LH threads. Also, all that carbon dust from the worn brushes makes this a VERY messy job. Disassemble the motor on some newspapers or similar disposable material.
It's been a while, but I THINK these are the brushes I used:
https://www.amazon.com/gp/aw/d/B002SB0J46?psc=1&ref=ppx_pop_mob_b_asin_title https://www.amazon.com/gp/aw/d/B002SB0J46?psc=1&ref=ppx_pop_mob_b_asin_title
Amazon has a huge selection if you search for "carbon brushes". Add a dimension (10 mm, just a guess) to narrow down the list. Sorry I can't remember exactly which brushes I used. I ordered about a half dozen varieties to experiment but can't find my notes.
Old May 16, 2019 | 12:01 AM
BlackKat's Avatar
https://www.amazon.com/gp/aw/d/B002S...b_b_asin_title
Awesome! This definitely provides an option.
Thanks a bunch!
Old Jun 29, 2019 | 10:27 PM
BlackKat's Avatar
Thanks a bunch!
Hello kr98664,
I started a teardown on a used fan motor for a rebuild but seem to be stuck. Have a look at my pictures here and let me know your thoughts.
https://www.jaguarforums.com/forum/x...d-fail-219818/
Old Jun 29, 2019 | 11:03 PM
kr98664's Avatar
Is that a brushless motor? They typically last forever if there are no brushes or commutator to wear down. The bearings will eventually wear out and need to be replaced, but that's about it.
Old Jun 30, 2019 | 11:57 AM
BlackKat's Avatar
Yours did not look the same? It should be the same fan for the S Type.
Old Jun 30, 2019 | 12:09 PM
kr98664's Avatar
The motor on my ‘02 looks very different. It was maybe 4” diameter by 4” long. Yours looks shorter but wider. Mine also did not have the big aluminum heatsink casting like yours.
Edit: Here's a picture I saved showing the part number. The brushes are under the end closest to the connector. The far end (bottom of the pic) has the shaft for the fan blade. You can't see much of the shaft because of the camera angle.
Old Jun 30, 2019 | 01:34 PM
BlackKat's Avatar
Gotcha! Looks like the fan motor changed at X202 model. Thanks again. I managed to tear down a little more. I'll post updates on the other thread.
Thanks again!
03Xtype
May 19, 2012 07:31 PM
bsprowls
Jan 20, 2012 09:26 PM
bsprowls
Jul 15, 2011 11:24 PM
blaksplash
86
Jun 20, 2011 05:14 AM
amb732
Jan 7, 2008 05:12 PM
