O2 choice ?
Old Jul 28, 2015 | 05:07 AM
ZenFly's Avatar
Default O2 choice ?
I need a downstream O2 sensor.. Just checking ebay for prices,, I see mostly Bosch, Denso , Walker and prices from $38 (no name) to over $200 for one name brand. Any advice here ? The shop wants over $300 to install one and I just happily paid them $800+ for coils and plugs. (2 coils bad/changed them all) I think I can change this O2 out myself.. Thanks for any help on choice of part..
Old Jul 28, 2015 | 06:58 AM
Box's Avatar
Box
The system is a Denso system. They are some of the most reasonable priced as well.
Old Jul 28, 2015 | 11:23 AM
Jon89's Avatar
I've never had a problem with a Denso replacement sensor. Had to put a couple of them in my wife's now long-gone 2000 Lexus RX300 SUV way back in 2004. No issues at all after replacement....
Just be sure to shop around for the best deal....
Old Jul 28, 2015 | 11:43 AM
JagV8's Avatar
And being downstream(s) they'll be the cheaper-technology non-wideband (non-linear) kind.
Old Jul 28, 2015 | 01:45 PM
tbird6's Avatar
Get the part number you want and check Amazon and Rock Auto too.
Old Jul 28, 2015 | 04:07 PM
ZenFly's Avatar
This looks like the OEM ..
Rock Auto (thanks) says this is the right one..
https://www.rockauto.com/catalog/mor...id=416&jpid=11
Amazon has the same
Amazon.com: Denso 234-4951 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive Amazon.com: Denso 234-4951 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive
Old Jul 29, 2015 | 08:14 PM
Don B's Avatar
ZenFly,
That part number looks correct. The Denso Part Finder is a good place to confirm part numbers:
Find My Part | DENSO Auto Parts
Cheers,
Don
Old Jul 30, 2015 | 04:37 AM
ZenFly's Avatar
Thanks.. That does look right..
Old Sep 15, 2015 | 08:49 AM
ZenFly's Avatar
I'm bring this back up.. I changed the sensor with the correct part and turned off the ck engine light... Well the light is back on with the same code so I'm thinking it's the catalytic converter that isn't functioning.. I've only had this car for 3mos and 2000 mi and it runs great. I read up on this a bit before doing anything and seem to remember that fouled plugs and injectors can cause this condition but they check out good.. Any thoughts ? Thanks
Old Sep 15, 2015 | 08:53 AM
JagV8's Avatar
So... which code?
Old Sep 15, 2015 | 09:14 AM
ZenFly's Avatar
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Thats From my iCarsoft tester... I also got the test from the best shop here Eurotec who said "the downstream sensor bank 1 needs to be replaced" and gave me a price of a little over $300 to replace it.. I bought the part off ebay for $59 and it took 10 min to put in. The light stayed off longer than with the old one.
Old Sep 15, 2015 | 09:34 AM
JagV8's Avatar
Oh dear, yes, that does tend to be a bad cat. Borescope / IR gun to check.
Old Sep 15, 2015 | 10:01 AM
ZenFly's Avatar
I just read another thread here from 2012 that you (JagV8)helped on also where the dealer R&R price was $3500 for both. Some posts there mention after market cats and a muffler shop.. . one post there mentioned Magnaflow (I think) .. What do you think about after market cats ? any suggestions on brand ?
https://www.jaguarforums.com/forum/s...s-@@@-@-75402/
Old Sep 15, 2015 | 10:29 AM
JagV8's Avatar
I'm in England.
Old Sep 15, 2015 | 11:08 AM
Jon89's Avatar
Go to a decent muffler shop and have them take a look. Some shops will not charge you for their initial analysis. Poke around on the web, check their online reviews, make some phone calls, then select the shop you find to be the most trustworthy....
Old Sep 15, 2015 | 02:44 PM
tbird6's Avatar
Before you do anything I would swap your O2 sensors just to make sure the code stays on that side. You never know plus it's very easy on the S Type.
I would use an aftermarket cat and there are plenty of them to choose from.
Wolfy
May 28, 2024 08:06 AM
GGabriel
Nov 22, 2018 03:53 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
Jaguar Forums Editor
Jaguar Press release
Sep 17, 2015 11:18 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
