oh no.. torque converter
Old Jan 30, 2015 | 01:29 PM
ONEsicJAG's Avatar
Default oh no.. torque converter
Pretty sure my torque converter took a crap on me. I pulled away from a red light and when the car went to upshift it just stopped accelerating.
Old Jan 30, 2015 | 02:10 PM
JagV8's Avatar
No message on the message centre?
Any OBD codes?
I'd not assume it's the TC.
Old Jan 30, 2015 | 05:00 PM
ONEsicJAG's Avatar
I haven't pulled any codes yet. I didn't notice a gearbox fault message.
Old Jan 30, 2015 | 07:53 PM
hilaryv215's Avatar
That happened to me like beginning of Dec.... I got stuck in a shifted position.... Than next day my car started making weird sounds and smells....
Good luck...
Old Jan 30, 2015 | 11:28 PM
Warspite's Avatar
That is the downside of the transmission being a sealed unit. Can't inspect the fluid without dropping the pan. And seldom will a transmission shop replace the torque converter alone. They try to get you a total rebuild.
Old Jan 31, 2015 | 03:44 PM
Tame Technician's Avatar
you can drain and fill the fluid as much as you like, its not sealed at all.
You need to pull the codes first, there are a load of things more likely to go wrong than the torque converter.
Old Feb 1, 2015 | 09:57 AM
JagV8's Avatar
+1 it's simply not a sealed unit, that's a myth. Let's kill the myth.
Old Feb 1, 2015 | 10:12 AM
jagastruckerhoodornament's Avatar
I assume the vehicle made it back home? Scanned for codes?
Checking on the fluid:
You can, carefully, with the passenger's side of the vehicle on jack stands or a ramp, slowly, slowly, carefully, using a hex tool, slightly, slightly open the metal fill port on the passenger-side of the transmission (on the body of the transmission, above the plastic pan). Once a little bit of fluid streams out, capture it in a clear container, and quickly tighten that fill hole. That's how I discovered my S-Type's need for new transmission fluid soon after buying it. Not the smartest way, I know, but if someone knows an easier way that doesn't risk losing a lot more fluid than you intend...
It may not be the torque converter going. It could be a symptom of low transmission fluid, bad solenoid, slipping transmission...
I wouldn't drive it until I had a reasonable clue as to what is going on.
Old Feb 1, 2015 | 11:51 AM
ONEsicJAG's Avatar
The cat is completely immobile on its own. I can put it in D, R, 2,3,4,5.. and get out of the car. It doesn't move. The drive shaft isn't spinning and I can here the load change when I move out of park.
Old Feb 1, 2015 | 01:28 PM
JagV8's Avatar
Could it be one or both bolts for the shifter cable on the side of the trans? They've a habit of coming loose or dropping out. See other threads about them.
Old Feb 2, 2015 | 08:40 AM
Jon89's Avatar
Yep. That's the first thing to check. Two 8mm bolts that tend to back off and drop out over time. They should be snugged up with an 8mm box wrench every time you're underneath the car for an oil & filter change, etc. Takes about 30 seconds to locate and tighten them. You must use an 8mm box wrench because there is not enough working room to get a socket wrench on those bolts....
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Poet
Oct 6, 2015 09:40 PM
Jagfastic
Sep 14, 2015 07:41 PM
chatmanx
Sep 11, 2015 07:17 PM
