Oil catch can
Old Dec 19, 2020 | 10:06 PM
Kwakaturbo?'s Avatar
Default Oil catch can
Hi all has any one on here fitted a oil catch can to a 4 litre v8 and a Pod filter if so any pics please
Old Dec 20, 2020 | 12:28 AM
Datsports's Avatar
Not exactly but I have fitted both to a STR .
You’re going to get some flack on here about your pod filter idea.
There really is no advantage sucking hot engine bay air into your intake.
though done correctly with a heat shield, you can get a slight advantage.
though a good panel K&N replacement that suits the factory airbox would be satisfactory.
and already has cold air .
and that is then still debatable as to whether that’s better than factory or not as well.
as the oil residue that this type of filter requires does emit onto the airflow meter with time.
so just a little bit more service work every service.
here’s a link here which includes my installation.
https://www.jaguarforums.com/forum/x...intake-164444/
Old Dec 20, 2020 | 01:16 AM
Default Thanks
Thanks for they reply I was just testing the waters re pod but as for the catch can as yours is the 4.2 do you or does anyone have a diagram on how I can plumb one on a 4.0 v8 thanks
Old Dec 20, 2020 | 01:57 AM
Datsports's Avatar
The 4.2 and 4.2 sc PCV are identical. So as far as plumbing goes , It’s the same As the STR .
have a look at the link I sent . It’s simply put in the pcv pipe . As shown
Old Dec 20, 2020 | 02:11 PM
hi Datsports mine is the early 4litre v8 the plumbing is different to the 4.2 completely different inlet set up
Old Dec 21, 2020 | 04:00 AM
Datsports's Avatar
The concept is the same. The location is the same. And the plumbing is the same.
And can be pretty much be found to be the same on most makes and models of engine.
look here
https://www.jaguarforums.com/forum/s...cement-216719/
Old Dec 22, 2020 | 11:21 AM
JagV8's Avatar
Before you spend time on this, have you checked your chain tensioners etc? (See the many threads.)
Old Dec 22, 2020 | 12:34 PM
hi jagv8 thanks for your reply there’s nothing wrong with the engine I was asking as to see if there’s any benefits to this and for dress up
Old Dec 22, 2020 | 01:35 PM
JagV8's Avatar
But did you check those tensioners??? Your engine will be destroyed if you have any of the old kinds.
I saw that. With a wrecked engine (see above) it's irrelevant.
Six Rotors
Canada
May 9, 2021 01:46 PM
Dealersadvocate
Aug 26, 2020 09:45 PM
daxter1987
Jan 26, 2015 01:56 PM
jimmypopjunkie
Jun 13, 2011 06:51 PM
marksj64
Nov 7, 2007 09:11 PM
