oil pressure light
Old May 10, 2010 | 12:13 AM
fordboy's Avatar
Default oil pressure light
I have a 03 s-type 3.0 that the oil light started comming on. It comes on when the engine is idling or below 1000 rpm. There is no metal in the oil and I just changed the oil. I cut the oil filter open and didn't see anything in there either. I was wondering if anyone else has had this problem? Is it just the sensor going out or what? The engine seems to be working ok, no noises or knocking. Makes me nervous sitting at a light with the oil light on. Thank for any help and keep up all the good work on the forum.
Old May 10, 2010 | 04:53 AM
JagV8's Avatar
Silly question but has to be asked: is the oil at the right level on the dipstick?
Was all OK before you changed the oil?
What oil and filter did you use?
If OE ones, you may want to replace the sensor to check it's not faulty and if that doesn't fix it then serious investigation is needed urgently. I do not recall anyone reporting this before!
Old May 10, 2010 | 11:57 PM
fordboy's Avatar
It started before the oil change but after I did the IMT o-rings and valve cover gaskets. It started all the sudden. Was working great one day the next the light was coming on. Using valvoline syn oil and a K&N oil filter. Yes the oil is full.lol.
Old May 11, 2010 | 02:12 AM
JagV8's Avatar
If it were mine I'd change the sensor and also put on a Jag oil filter.
I'd be using 5W30 oil in case you're not, but I can't see it being that.
As the oil's new(ish) I'd filter it (and check the filter) and put it back in.
Old May 11, 2010 | 06:14 AM
Jon89's Avatar
In two similar situations in the distant past with other (non-Jaguar) vehicles, the problem both times was caused by a failed oil pressure sending unit. Cheap and easy fix with those cars because you could get to the sending units very easily and they just screw in and out on the engine block. With Jaguar, who knows....
Old May 19, 2010 | 02:08 PM
dperry's Avatar
I think that I'm having the same problem with my car, who knows where I can find the sending unit I've looked all around the engine with no luck. Thanks for the info
Old May 19, 2010 | 02:21 PM
JagV8's Avatar
Workshop manual $10 ebay
Old May 10, 2013 | 12:09 PM
catstyle's Avatar
Any updates on what was causing that?
Old May 10, 2013 | 12:49 PM
JagV8's Avatar
3 year old thread. Try a PM to the guy but don't expect a reply.
Old Jun 24, 2014 | 04:22 PM
omoledstronger's Avatar
goodday. i also have jaguar s type 2003 model now i am experiencing similar problem wth d car. one am driving below 1000 rpm check engine light always stay on. and at times it stays on all thru even at high speed. could u help me out on what u did to ur issue then. i will apreciate a quick response.
Old Jul 8, 2014 | 09:37 PM
catstyle's Avatar
My 05 3.0L Jag had the same problem and it got resolved by changing the sensor.
Old Jun 3, 2016 | 10:12 PM
ndy4eva's Avatar
Thanks, I'm getting this symptom on my 03 3.0l s-type as well. I talked to my mechanic, and I'm planning to change the Oil Pressure Sender / Switch. Hope this resolves my problem as well.
Old Jun 4, 2016 | 05:27 PM
gm_jim's Avatar
You might consider trying 0W-40 Mobil 1. A little thicker. It's one of the Jaguar recommended alternatives for my car and I've been using it with success.
Old Jun 13, 2016 | 01:32 AM
ndy4eva's Avatar
Okay, I might try this first then. I will post the result after.
Thanks!
Old Jun 2, 2017 | 12:51 PM
Roger S Surroz's Avatar
I looked it up on All Data and it shows the sending unit above where the oil filter housing is located I'm ordering a new one for my 03 jag s 3.0 only 6.00 from Advanced after shop discount.
Old Jun 2, 2017 | 01:33 PM
JagV8's Avatar
I hope he found it some time in the last 7 YEARS!!
Meanwhile are you a spammer?
Old Jun 2, 2017 | 05:26 PM
Maybe he will reveal all in the new members section?
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
Dymaxxion
Sep 4, 2015 02:40 PM
bdboyle
Sep 4, 2015 06:16 AM
OkieTim
Sep 2, 2015 12:48 PM
