P0101
Old Jan 10, 2015 | 11:40 AM
macke's Avatar
Smile P0101
I have a 2006 s type 4.2 wont pass emission code p0101 came up they said maf , so I replaced air filter and cleaned maf sensor disconnected battery cable for a minute to reset drove about 60 miles and cel came back on ,do u think its vacuum leakes ,car runs good, when I start it up it idles up and down between .5 and 1 rpm for a 2 minutes then it smooths out at just below 1000 rpm , one time it stalled when I came to a stop ,but it started up and drove ok ,also transmission sometimes jerks when changing gears. I forgot to mention there is small leak under the driverside wheel maybe transmission leak the car has 105000 miles never spark plug change. I think that's it a lot to swallow uh.please help .
Old Jan 10, 2015 | 12:45 PM
Hi Macke, I've moved your thread to the S Type tech section.
Old Jan 11, 2015 | 09:00 AM
JagV8's Avatar
Grab JTIS / codes PDF and it has a list of all the known causes.
Inevitably they'll include bad sensor, wiring etc.
Old Jan 11, 2015 | 10:59 AM
macke's Avatar
I thought all my information was entered if not where is the signature section. anyway I may have found my problem , I both the car with 45000 miles on it and I never changed the spark plugs,it has 105000 miles on it. doesn't the cel come on after certain miles intervals/ thank you
Old Jan 11, 2015 | 11:05 AM
JagV8's Avatar
Only the diesel has a Service Due indicator - and doesn't seem very good, either.
I can't see it being plugs as they're good for 100K miles by the book so probably good for quite a lot more in actuality - but I'd change at the service figure anyway.
Bad plug(s) are almost guaranteed never to cause P0101 I reckon.
It really really is worth looking at the known causes stuff......
Old Jan 11, 2015 | 11:32 AM
macke's Avatar
Default macke
well where do start , p0101 says mass air flow I clean maf sensor and replaced air filter ,also unplugged maf sensor and car cut off. that mean sensor is ok right.
Old Jan 11, 2015 | 12:10 PM
JagV8's Avatar
Nope, it means it can tell when it's not there at all. It's #1 suspect.
Old Jan 11, 2015 | 12:37 PM
macke's Avatar
so u think its maf sensor I was told with the car running u unplug maf sensor and it cuts off its not the maf sensor, I also tried to start it with it unplugged and it started up and it cut off. is that true
Old Jan 11, 2015 | 12:42 PM
JagV8's Avatar
Who told you that?
Why should it be true and if it is what does it prove? Very little.
It's no way to treat any modern car. They have OBD II and it's what you should be using unless you'd rather swap part and hope. I'd look at fuel trims, though you may well have a bad MAF.
Old Jan 11, 2015 | 04:19 PM
macke's Avatar
I got that off you tube , I will go tomorrow and buy maf sensor ,if that doesn't work do I need anything while im there. thank you
Old Jan 11, 2015 | 05:18 PM
QuartzSTypeR's Avatar
I would recommend an OEM MAFS; aftermarket ones have a higher defect rate.
Old Jan 11, 2015 | 05:35 PM
joycesjag's Avatar
Well hell, if it came off the internet you know its the truth!
powerhouse
Jan 30, 2017 12:17 PM
javigo1971
Sep 28, 2014 07:47 PM
Promech
Feb 11, 2014 01:17 PM
jaggachafen
Sep 18, 2012 12:20 PM
AnthonyF
Jul 25, 2010 11:25 AM
