P0628 05 s-type 3.0l
Old May 23, 2017 | 02:25 PM
dccturbo14's Avatar
Default P0628 05 s-type 3.0l
Car wont start. Checked power at main fuel pump on passenger side while cycling key on and cranking. No power. I have power at the inertia switch fuse. Either we have a problem with the rear electronic mondule in the right rear, pcm or alarm system is causing this. Thoughts?
Old May 23, 2017 | 02:27 PM
dccturbo14's Avatar
Also swapped relays. No change...
Old May 23, 2017 | 07:40 PM
aholbro1's Avatar
PAts flashing any codes?
Evidence of water in the boot floor?
Old May 24, 2017 | 06:18 AM
dccturbo14's Avatar
yep! I found water under the rear seat in the corner where the main fuel pump is. It wasnt a puddle but the installation sheet that covers the pumps was soaked in that corner.
Old May 24, 2017 | 06:19 AM
dccturbo14's Avatar
no flasing codes.
Old May 24, 2017 | 06:33 AM
JagV8's Avatar
Water in the boot (trunk)?
If it won't start you almost always have codes other than P0628 - have you fixed that?
Old May 24, 2017 | 06:56 AM
dccturbo14's Avatar
what boot? Where exactly is it in the trunk. We did get a can bus code also.
Old May 24, 2017 | 07:50 AM
aholbro1's Avatar
Boot=Trunk
Boot floor = bottom of trunk
(The bonnet is where you think the hood is, Wings have mistakenly been called fenders....and the "offside" is the side on which is mounted the "motheras seat" according to my kids when they were toddlers)
Old May 24, 2017 | 08:05 AM
dccturbo14's Avatar
Boot=Trunk
O lol. No water in trunk/boot
al 350i
Nov 2, 2016 08:37 AM
