P0781 transmission issues
Old Sep 21, 2010 | 03:42 PM
phaelax's Avatar
Default P0781 transmission issues
Been an ongoing issue for awhile and it's getting progressively worse. The upshift from 1st to 2nd is pretty harsh unless I really watch it. The RPMs rev too high and if I'm not careful it'll just miss the shift and get stuck in gear until I restart the car.
I went to Advanced Auto, they pulled code P0781 and when pulling up the definitions to the code they pointed at GM and seemed confused when I said it's more likely to match up with the Ford listing. Not 100% positive this code would match directly with Ford, but the description sounds right:
Detected the engine RPM did not drop during the 1-2 upshift.
Probable causes:
1. Poor connection at transmission
2. Open or shorted circuit condition
3. Internal transmission problem
That's it for my diagnosis, any advice? Car isn't under warranty anymore which is why I haven't taken it into the dealership yet.
Old Sep 21, 2010 | 06:29 PM
JagV8's Avatar
Have a look for JTB00072 (v2, i.e. JTB00072v2)
Dealer reflashes the TCM. Should be quite cheap.
Old Sep 22, 2010 | 03:44 AM
Cadillac's Avatar
I do have GM Trouble Codes and 781 exactly indicates 1-2 Shift Malfunction
Old Sep 22, 2010 | 04:02 AM
JagV8's Avatar
Why not follow the TSB I posted - take car to dealer and they'll do it for next to nothing.
(It's not a GM car or tranny, btw. AND there's the TSB specifically about this.)
Old Sep 22, 2010 | 05:56 AM
bfsgross's Avatar
I'd follow Jagv8's advice. Jaguar dealership flashed both the TCM and ECU on my 03 STR for $110. Your 03 STR has a ZF trans. (German) using codes germain to Ford due to Jaguar being basically being a Ford product.
Old Sep 22, 2010 | 01:01 PM
Leedsman's Avatar
In my investigations re. another ZF problem, more than once your problem proved to be simple lack of ATF fluid. Worth a look. Hope this helps.
Leedsman.
Old Sep 22, 2010 | 01:44 PM
JagV8's Avatar
Thing is: there's the TSB that covers exactly that code and is not about a lack of fluid. So it may be worth taking the TSB at face value first. It will likely be cheaper, too.
Old Sep 23, 2010 | 02:01 PM
Leedsman's Avatar
Have a look at Jimmy1's contribution in "General Tech Help" and its associated thread. Could be an interesting read.
Leedsman.
Old Sep 23, 2010 | 07:00 PM
phaelax's Avatar
I'll call the dealership and ask about flashing the TCM. I know someone who specializes in transmissions and said he'd flush it for $100.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Sep 25, 2015 11:09 AM
carelm
Sep 5, 2015 01:13 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
