p1586 failsafe mode/no start
Old Feb 17, 2013 | 10:01 AM
I-jag's Avatar
Default p1586 failsafe mode/no start
my car hasnt started for almost a month now. since then ive replaced the TB with a brand new one. new plugs and coils, new upper intake gaskets, and new valve cover gaskets.
I've managed to clear 3 of the 4 codes that kept coming up, but now this 1586 wont clear even with a new tb and is still in failsafe mode and wont start.
do i need to get the failsafe mode cleared before its able to start or does any of you think it might be another prob altogether????
ive also tried doing a hard reset and that doesnt help either. idk. pretty frustrated
Old Feb 17, 2013 | 10:05 AM
I-jag's Avatar
i just went and tried it again and all it does is start for a few seconds and dies
Old Feb 17, 2013 | 10:33 AM
Have you checked the fuel pressure?
Old Feb 17, 2013 | 12:46 PM
JagV8's Avatar
If I understand it properly, P1586 is for the module that controls the TB. That looks to be what the codes PDF says. Did you look at that?
Also worth changing the hoses that are forever reported on here for that era engine.
You could have a blocked fuel filter, btw.
Old Feb 17, 2013 | 02:20 PM
I-jag's Avatar
how do you check the fuel pressure? i did depress a valve stem in the fuel line and fuel came out. so theres at least pressure there. it was in front of the engine next to the air intake and tb.
jag8, are you talkin bout that elbow under the fuel rail?. (i forgot what thats called)ive read alot about that one. not sure which other ones your mentioning
Old Feb 17, 2013 | 03:14 PM
abonano's Avatar
+1 to a possible blocked fuel fiter or a DOA fuel pump - often you will find when these cars sit for a while (for some reason) the fuel pump dies a sudden death. Also, check the inertia switch under the dashboard - drver's side and listen for the "2 second woosh" when turning the ignition key to "run".
Fuel pressure at start up should be at least 40 psi - fuel should spray out of the fuel rail, not dribble - if it dribbles... this would lead to the fuel pump being DOA...
I would also check electrical connector to each fuel injector as well....ensure they are on real tight...Good Luck
Old Feb 19, 2013 | 07:35 PM
I-jag's Avatar
i had towed to jaguar and they said that they want to swap the new tb for the old one. there thinkin its a bad tb which i highly doubt. but they cant even get the code to clear out. they reflashed the pcm and said it still wouldnt clear.
i ended up changing the fuel filter, although iit didnt work i still got a whole lot more out of it starting than i ever did before. i put some injector cleaner in there too, which i think helped as well.
does anybody know why a code wouldnt clear like that? even by reflashing the pcm?!
Old Feb 19, 2013 | 07:41 PM
I-jag's Avatar
oh and they said the last code they read from my car when i had it in there 6 mos. ago was p1584 which was the tb actuator. since then its been cleared, in fact its not even stored in it anymore (i guess it stores codes? idk) anyways thats not in the memory but this 1586 wont go away. any thoughts?????????
Old Feb 20, 2013 | 02:49 AM
JagV8's Avatar
post #4
Old Mar 30, 2013 | 11:09 PM
sgkingd's Avatar
Did you ever figure out how to correct this issue? Im having the same problem.
Old Mar 31, 2013 | 08:53 AM
JagV8's Avatar
Please add details (see below).
How old is the battery?
Old Apr 1, 2013 | 08:50 PM
sgkingd's Avatar
its fairly new been having over heating issues I replaced head gaskets, thermo, radiator,water pump, expansion tank, yo name it. I was bleeding the system after adding coolant and it shut off and went into safe mode and wiill not start. If I cant solve the issue im gonna put in a 4.3 chevy motor.
Old Apr 2, 2013 | 06:50 AM
I-jag's Avatar
yeah I finally got it fixed. it ended up being the ECM. the jag dealer said he never seen one go out before. they found out by checking the ground points in the car and found out there was no ground coming out of the ECM to the coils. idk if that could b the prob but it wouldn't hurt to check.
Old Apr 2, 2013 | 08:25 AM
JagV8's Avatar
P1586 is not about coils. The PCM (aka ECM) chooses not to ground signals when it's chosen not to start the car....
Best to find out why it's made that decision.
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
