P2099 Post Catalyst Fuel Trim System Too Rich (Bank 2)
Old Feb 8, 2012 | 02:10 PM
Sixx Dogg's Avatar
Default P2099 Post Catalyst Fuel Trim System Too Rich (Bank 2)
Hello everyone! Ok....I have a 2006 s type sport - 3.0 112000km on her...
recently have had the following done - (past few weeks)
Imt O Rings
Inlet Gaskets or seals...
New Plugs
replaced #2 bank 2 sensor
replaced mass air flow sensor
replaced #1 sensor on bank 2
All other codes have gone away...but this 2099 keeps turning on my engine light....it is driving me CRAZY...
Thank you.
Old Feb 8, 2012 | 05:20 PM
xjrguy's Avatar
Imt O Rings
New Plugs
Thank you.
You have two likely possibilities. At your mileage, you may actually have a failed catalyst; that would be a bummer. Next, the 'Sub-feedback' adaptions may have never been cleared after the new sensors. Try this:
The reason the fault is still present after your rectification is because the sub-feedback* adaption value will not have had time to re-adapt after the new sensors are fitted. The procedure to get around this situation is to disconnect the battery for about 10 minutes to reset the sub-feedback adaption values. This procedure will reset all adaption values and so the ignition should be cycled (on for 10 seconds, off for 10 seconds) a couple of times to allow closed throttle learning to happen.
It's worth a try.......
Old Feb 8, 2012 | 06:17 PM
Sixx Dogg's Avatar
Thank you for your reply. So clear the code first...then disconnect the battery for 10 min? A few questions regarding this....
Will I have to reprogram my blue tooth, radio and seats - also will I need the code for the raido to get it to work? Any other surprises when disconnecting the battery?
I appreciate the help...thank you.
(I have the touch screen nav in my car)
Old Feb 9, 2012 | 04:45 AM
JagV8's Avatar
Battery disconnect will clear the code.
Usually USA/Can don't have radio codes but goo idea to have it available. I think the BT will be kept (not sure). Same with the seats. One-touch windows will need redoing as per handbook.
Old Feb 9, 2012 | 08:42 AM
xjrguy's Avatar
Actually, John, the battery disconnection won't clear any codes; that hasn't cleared codes since the XJ40's. He'll need to use a scantool to reset.
Good on all other points, though if the radio is improperly set for a non-US/Canada market, he may need a code. hat does happen sometimes.
Also, once the battery is re-connected, wait 30 seconds before turning on the ignition so the Climate Control can have time to re-index the mode doors.
Cheers,
Old Feb 9, 2012 | 09:07 AM
JagV8's Avatar
Er.... people post here & on the UK forum that they've cleared codes (*) by disconnecting the battery of an S-Type. What's going on? Who's right?
(*) just the ones in the PCM and of course not permanent / history codes
Old Feb 9, 2012 | 01:12 PM
Sixx Dogg's Avatar
Update - well I had the code cleared yesterday from my mechanic - and after a few weeks of it turning on....its been off all day today....I am keeping my fingers crossed!!! Ill keep you all updated!!
Old Jul 13, 2013 | 02:42 PM
Dr. JC's Avatar
Did you ever get a definitive resolution on your 2099 code? My 2006 STR threw this code today. Rear O2 sensors? Car has 72k miles on it so I dont imagine the cat is bad but I guess it could be.
Thanks!
JC
Old Jul 13, 2013 | 03:02 PM
police666's Avatar
A misfire can destroy cats in days depending on the severity, so milage is no guarantee the cats are good
Old Jul 14, 2013 | 09:08 AM
JagV8's Avatar
There are specific codes for the sensors so you're likely looking at something else. Maybe a failing cat conv.
Old Oct 11, 2015 | 10:43 AM
Dr. JC's Avatar
I know this is a really late reply (years), but I went overseas on a work assignment and left the issue unresolved. A month ago I replaced all 4 oxygen sensors and the code and engine light are resolved (even though no specific codes were thrown indicating a bad sensor). Thank God it wasn't the cats.
Old Oct 11, 2015 | 01:45 PM
JagV8's Avatar
Good to hear!
Old Oct 12, 2015 | 11:58 AM
tbird6's Avatar
Great that you posted back after all that time too!
Old Oct 13, 2015 | 09:00 PM
'05 STR's Avatar
I've tried on my '05 STR and no, they stayed. I have a scanner but decided to try just for the heck of it. I also found it interesting that the readiness monitors were set after only a short drive, most cars take between many miles and eternity.
toronadomike
Jan 22, 2026 10:13 PM
way2far
Aug 31, 2022 09:26 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
