Parking brake stuck
Old Dec 12, 2014 | 09:09 PM
Beerline123's Avatar
Question Parking brake stuck
Had the yellow light with parking brake fault written. Using scan gauge 2 I got no codes found or pending. Removed negative from battery waited 10 minutes started vehicle pumped brakes and pulled up on brake swith and the brake released. Putting car into gear and drove a few feet then placed into park the parking brake did not engage which I believe it normally does. I am able to engage the brake on and off by the parking brake switch. At the current time to prevent another locked up parking brake I am holding the parking brake switch down as I turn off the car and pull the key out which seems to prevent the parking brake goin on. Any suggestions to get this back to normal would be appreciated. Also my battery is brand new. TIA
Old Dec 12, 2014 | 09:21 PM
Wink Sorry guy's I have a 2005 s type 4.2 auto 68,000
I'll do my profile next. Thanks for your patience
Old Dec 13, 2014 | 09:16 AM
Mikey's Avatar
Pulling up on the lever engages the EPB not releases. Has the warning gone away? Does the brake work normally now?
Old Dec 13, 2014 | 06:00 PM
Default Stuck parking brake
Thanks miKey for your interest. The light is out. I'm able to engage and disengage the brake the only thing it does not do is to engage the parking brake when placed into park. Do you know if I need a special scanner to pick up dtc's for the parking brake module. I have a scan gauge 2 which supposedly reads all makes but when I scan the car when the light was on and it read parking break fault no codes where found. I know there's at least 8 dtc,s for the parking brake in the manual I have.TIA
Old Dec 14, 2014 | 03:25 AM
JagV8's Avatar
Mine doesn't engage when put into park until you switch engine off & remove key.
Old Dec 14, 2014 | 10:46 AM
Default Thanks jv8
I will look into that I believe your right. The cars my wife's so I hardly ever drive it until she tells me there's a problem . I need to read this mitchel online manual I bought the other day. This vehicle has a lot of electronic systems. I appreciate everyone picking up my mistakes. It appears that the parking brake system seems to be functioning correctly now. I'll just wait to see if it locks up again. Do you know whether my scan gauge 2 should be able to pick up any dtc's. I found it hard to believe that with that yellow light and the words parking brake fault that there wouldn't be any codes . TIA
Old Dec 14, 2014 | 11:23 AM
JagV8's Avatar
Should be codes in the EPB module which that tool's software will fail to read I expect.
Old Dec 14, 2014 | 12:09 PM
Mikey's Avatar
I've had the EPB fail come up momentarily only to disappear with no other issues. Have you looked to see that the trunk/boot floor is bone dry? A bit of water is not rare and drives the computers nuts.
In your posts above, it's not clear if the brake actually failed to release or not at any time, or there was just a warning.
Old Dec 14, 2014 | 12:37 PM
JagV8's Avatar
I suspect low battery when it happened.
Probably an unmaintained EPB as well.
Old Dec 14, 2014 | 05:49 PM
wilewgn's Avatar
I think the battery also. I was having lots of EPB problems and my battery seemed fine even though it was the original. I replaced the battery and no EPB problems since, coming up on two years now.
Old Dec 14, 2014 | 09:14 PM
The battery is brand new but I'll multimeter the battery. It was interesting what one of you guys mentioned water because my wife said the trunk had accidenly opened on here while parked in our driveway and it was lightly raining so even though it's been a few days I'll check the trunks bottom. The brake has been working fine last time I checked but we don't drive the car daily. Tia
Old Dec 14, 2014 | 09:43 PM
Trunk is dry didn't look like any water was in there. Battery is 12.30 volts which is about right. The only thing it's not doing is setting the brake when I turn the car off after placing it into park. I can use the brake switch to engage or disengage. Now I did the procedure of holding down the brake switch while at the same time taking the key out this was supposed to prevent the brake from engaging when I shut the car off and I did this in the beginning of the problem so my wife wouldn't get stuck somewhere. According to what I read the disabling feature is suppose to be reversed once I engage the car back into gear the next time I would start it. So I' m not sure if something's wrong or if I've disabled that feature. If the latter I need to know how to reset the brake? Tia
Old Dec 14, 2014 | 10:56 PM
abonano's Avatar
12.3V is questionable - should be in the 12.5 to 12.6V range. Getting the battery to this range might be key.
If your not using the car often - consider putting a trickle charger on the battery (I personally use C-Tek)
As far as disabling/enabling the EPB - it can be accomplished via dealer level diagnostic equipment.
Old Dec 15, 2014 | 09:35 AM
Mikey's Avatar
And?
Old Dec 15, 2014 | 03:01 PM
Default Mikey
Yes the brake actually locked up but so far it's been working. Thanks for all the guys who helped me. Happy holidays.
Old Dec 19, 2014 | 09:05 PM
MatthewAdan's Avatar
Same thing happened to my car today. I am going to try disconnecting the battery, see if there's water in the trunk, and any other suggestions I should do? I have to wait till tomorrow morning if its not raining but i found your post very useful and down to the wire of whats going on. I appreciate that.
Old Dec 20, 2014 | 02:46 AM
JagV8's Avatar
Check voltage engine off, after standing over night. Should be 12.5 or more.
Old Dec 20, 2014 | 10:08 AM
capt's Avatar
abonano, does this mean a mongoose can disable the EPB and if so will there be no message on dash?
Old Dec 20, 2014 | 10:45 AM
abonano's Avatar
Originally Posted by capt
abonano, does this mean a mongoose can disable the EPB and if so will there be no message on dash? Thanks
hi, I don't think any level diagnostic software can permanently disable the EPB. I'm not sure if Mongoose can access the EPB. I know WDS/IDS can access the EPB
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
sawduster
Sep 11, 2015 10:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
