Performance: Intake improvement
Old Aug 1, 2010 | 04:51 AM
avos's Avatar
Default Performance: Intake improvement
Posted this before but think it needs a separate thread:
https://www.jaguarforums.com/forum/showpost.php?p=223580&postcount=42
I would guess that this could bring 10 to maybe 20 extra horses top end, but it needs to be tested first on a flow bench to be sure that it does deliver.
To make it work, it would need to be precision welded, which I am not able to, however I have the full parts which I am willing to donate if someone can have it tested on a flowbench before and after the inserts that needs to be welded.
Old Aug 1, 2010 | 09:36 AM
bfsgross's Avatar
Hi Avos, looking forward to you releasing a twin screw blower with modified throttle body w/tube. What plugs should we run in our STR's? Be well and thank you for your interest in the STR.
Old Aug 1, 2010 | 10:50 AM
avos's Avatar
This proposed intake modification would be for any STR, not specificaly for a TS conversion at all. I think it could already provide extra power wihtout having to spin the eaton faster, but the more air you are sucking thru the better the effect.
I am still using NGK iridiums however 1 heat range colder for the extra power above stock.
PS For the TS conversion I am contemplating a totaly new intake but that nothing to do with what is proposed here.
Old Aug 1, 2010 | 11:27 AM
bfsgross's Avatar
Thanks Avos. As I am, I'm sure the STR's will be monitoring your progress.
Old Aug 1, 2010 | 01:02 PM
Enthusiast's Avatar
Andre,
How is the kit coming along?
Old Aug 2, 2010 | 01:28 AM
avos's Avatar
For the AJ27 and AJ34 XKRs the kit is ready, just need to test a AJ26 (which will be soon).
for the Stype it depends on the intake route, as that will determine the design of the SC fixings/connections heavily.
Old Aug 17, 2012 | 09:00 AM
Cambo's Avatar
Anything ever come of this intake modification?
Old Aug 17, 2012 | 04:54 PM
bfsgross's Avatar
Nada...nothing. Sure would be great to fit a twin screw (100+ hp and trq.) if/when it does.
hoodun
Feb 20, 2023 05:52 AM
xjrjag
Oct 12, 2015 03:16 PM
Johncy2000
Oct 2, 2015 01:05 AM
BlakeConverse
Sep 28, 2015 02:22 PM
