Pulling to the side randomly
Old Sep 7, 2018 | 06:14 AM
Ayden pahle's Avatar
Default Pulling to the side randomly
Hello this is my first post here but I've been prompted to join because my 2000 S-Type has randomly jerking to either side of the road. I have no idea what it could be any help would be appreciated
Old Sep 7, 2018 | 08:08 AM
JagV8's Avatar
Check suspension items. You'll have worn bushes or the like.
Old Sep 7, 2018 | 09:44 AM
S-Type Owner's Avatar
Is this when just driving down the road, or when braking?
Also, seeing as this is your first post, you should consider going to the New Members Forum and introducing yourself... the forum can be found here:
https://www.jaguarforums.com/forum/n...-intro-must-5/
Welcome.
Old Sep 7, 2018 | 10:18 AM
Thank you I'll take a look at them
Old Sep 7, 2018 | 10:20 AM
Welcome.
It does it while just driving down the road and it's kinda random and extreme when it dies. IllI look at the new members form thank you
Old Sep 7, 2018 | 12:20 PM
kr98664's Avatar
Welcome to the forum.
I went through something similar with my ‘02. On a rutted freeway, after hitting a bump it would practically change lanes by itself. The problem progressed quickly within only a couple of days and was quite spooky.
A local tire chain quickly diagnosed a bad ball joint on one side. The repair was very reasonable, under $300 IIRC. If you go to the dealer, they will replace the entire suspension arm and charge accordingly. The aftermarket repair (just the ball joint) was much more cost effective.
Be aware it can be tricky for us amateurs to properly diagnose suspensions faults. Sometimes the springs put a load on the worn components. Even with vehicle up on jacks, there may still be some tension present that masks play from worn parts.
Old Sep 7, 2018 | 02:51 PM
Thank you for that advice I will look into replacing the ball joints I looked at the right front tire and it is starting to toe in a bit.
quartetchiang
May 10, 2017 08:59 AM
Johnken
Apr 14, 2016 12:34 PM
Lancer-AM
May 16, 2012 10:56 AM
minigretzky
Sep 29, 2009 07:14 AM
mickflick777
Apr 23, 2008 10:37 PM
