Question about s type headlights
Old Jun 14, 2014 | 11:48 PM
Sonspit's Avatar
Default Question about s type headlights
Just noticed today (only had the car 12 days ) when I switch my headlights "on" the driver side is out but when its set to "auto" (where its been set since I purchased) both sides work just fine..
Does "auto" use a different set of bulbs than "on"?
Do I need to replace a bulb? If so which one?
any help is appreciated
Old Jun 15, 2014 | 10:08 AM
Mikey's Avatar
Originally Posted by Sonspit
J
Nope. Same bulbs.
Old Jun 16, 2014 | 08:42 AM
Sonspit's Avatar
Originally Posted by Mikey
Nope. Same bulbs.
Any idea on what's going on? Thats strange isn't it
Old Jun 16, 2014 | 11:33 AM
JagV8's Avatar
If it's a bother, grab a meter and go checking.
Old Jun 16, 2014 | 01:04 PM
tbird6's Avatar
I would suspect the head light switch. This is in the steering wheel stalk.
Before I changed it and would monkey around with the switch moving it back and forth to see if you can get the head light to come on. Sounds like a contact issue in a multi-function switch.
Old Jun 19, 2014 | 10:31 AM
sjgh's Avatar
That multi-fnction switch is flaky. Mine now flickers on the Auto position works fine in the ON position - sounds like a common type of issue. Not worth replacing.
Old Jun 19, 2014 | 07:05 PM
police666's Avatar
It will be when it causes a battery drain
Old Jun 20, 2014 | 11:45 AM
tbird6's Avatar
Yes it can cause all kinds of other weird problems so I would get it fixed.
Maybe I should expand on this a bit?
The S Type uses a ground switching arrangement. This means everything is live or hot all the time and the circuit is completed by grounding the circuit. So if the switch is not working right you have voltage running around who knows where.
In the old days the electrical systems worked just the opposite. The power was switched on and off. So if you had the same bad switch you generally would not see any problems until you actually moved the switch to turn something on.
stanjag
Dec 29, 2024 08:26 PM
XJLFTW
Jun 12, 2019 02:42 PM
rudelover2
Sep 11, 2015 08:53 PM
kesslari
Aug 31, 2015 04:53 AM
1100me
Aug 28, 2015 09:48 PM
