Question about windshield, ignition Cylinder and head light bulb
Old Jan 16, 2023 | 06:38 PM
e_brugal's Avatar
@xalty hi, I haven't change the cylinder but all part concerning that is solved I will change this week, and reporgaming of both key with a locksmith this weekend.
My problem now is with the headlights, as I mention several post back, I have the left side headlamps not working, and yesterday I went for a ride in the car, tryed the automatic headlamp and both sides turned on, when I turn the lights normal only righ side turnes on.
But today I tryed again turn on the lights in auto mode and only right side worked (back to 0)
My question was if someone knows why suddenly in auto mode left side headlamp worked but today didn't worked?
Also ask if is normal that the chrome par of the inside of the headlamps move loosly when I mové the bulb?
Sorry if this cause a problem but think that you got it the wrong way.
Thanks for any help with the headlamps
Old Jan 16, 2023 | 07:12 PM
scottjh9's Avatar
could be a problem in the module or that side getting glitchy. Maybe turn them on a wiggle wires. I think on/off is controlled by module grounding the circuit
Old Jan 16, 2023 | 07:13 PM
scottjh9's Avatar
Originally Posted by xalty
no they use the 2 working keys to add another
thanks
Old Jan 17, 2023 | 09:01 AM
S-Type Owner's Avatar
"Also ask if is normal that the chrome par of the inside of the headlamps move loosly when I mové the bulb?"
The chromed plastic reflector will move within the housing when pressure is applied (as when replacing the halogen lamp; hopefully, it will return to its original position when the pressure is removed. It is possible to damage the reflector, so I use a small hook tool to support the hinged end of the bale when a bulb replacement is performed.
jazzwineman
Sep 7, 2019 08:01 PM
Melindasue Larrabee
Mar 31, 2018 05:42 PM
ManClarky
Jan 8, 2014 09:46 AM
Jeh
XJ40 ( XJ81 )
20
Mar 17, 2012 08:15 PM
91xj6owner
XJ40 ( XJ81 )
Mar 11, 2010 04:18 AM
