Quiet/smooth S type?
Old Oct 10, 2014 | 09:56 PM
William1987's Avatar
Default Quiet/smooth S type?
Is there any way to smooth and quiet the ride in an S type? I'm guessing upgrading the suspension? anyone done this before?
Old Oct 11, 2014 | 03:03 AM
NikolaiDiqnov's Avatar
Can you be more specific- what exactly troubles you? The S-type has pretty comfortable ride. But if you feel that it is a little bit noisy you can try and replace the tires. Some tyre types and brands have higher noise ratio.
Old Oct 11, 2014 | 03:20 AM
JagV8's Avatar
Need car details - see below.
May be an old, worn suspension that hasn't been maintained/repaired?
Tyres make a huge difference and smaller rims, too.
Old Oct 11, 2014 | 05:14 AM
hilaryv215's Avatar
Hi,
So I have a 2002 s type , when I bought super quiet as soon as I let it sit 4 a month.... different story foundvout it needed NEW FRONT STRUTS AND CONTROL ARMS both sides, im a pretty penny in but its a whole new ride.
Good luck!
Btw lower control arms are $825 a piece if u search you can find the oem on a site fir $250-400 each, big savings
Old Oct 11, 2014 | 09:46 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
The S-Type has lots of sound deadening materials in it. It's the quietest car I've ever owned.
If yours is noisy, as others said, it might be your suspension parts making noises, or your tires are the culprit. I replaced the Michelin Pilots mine came with for a less expensive brand. Now, interior noise is noticeably louder on certain road surfaces (e.g. concrete with embedded stones). I should have stuck with Pilots which were extremely quiet on virtually all surfaces.
Also, check your exhaust system. It might be in need of repair.
Old Oct 12, 2014 | 06:19 AM
hilaryv215's Avatar
Jumpin jag,
Do u live in an area that gets winter snow and ice?
If so are the m.pilots winter tyres, do they hold up againt hydroplane?
I ask because I have firestone..., good tires from what Im told, theyre supposed to be all year but ibget a little slippage.
I have a little 3 year old to protect in the back I wanna get good tyres for winter.
Thanks 4 any input.
Btw I researched tyres but its not the same as getting a real persons feedback
Old Oct 12, 2014 | 06:22 AM
hilaryv215's Avatar
I drove 4 a while with my new suspension and wow, its like a brand new car. Its just as quiet as my aunts $100, 000 BMW.... well worth the $1, 200 I put in
Email if your on a budget ill give u the site I got my parts from..., used grade a green
Old Oct 12, 2014 | 10:04 AM
Mikey's Avatar
S-types have one of the smoothest and quietest rides of any car in it's class. Must be something wrong with yours.
Old Oct 12, 2014 | 11:41 AM
carelm's Avatar
I would recommend replacing the tires as well. Remember though, that the S-Type is tuned as a sports sedan. The S-Type I used to have was a really good handling car with lightening quick steering. Some of the uni-directional tires will be a bit noisy so you may want to do some comparison shopping.
Old Oct 12, 2014 | 12:51 PM
Originally Posted by hilaryv215
Jumpin jag,
Thanks 4 any input.
I'm only 45 minutes east of Philly; I'm in/out of the city all the time. As bad as last winter was, PA & NJ road crews do a remarkable job of keeping the roads clear in bad weather IMHO, so I had no problems in the snow with the new Pirelli Cinturato tires mounted on my '03 S-Type. The Michelin Pilots I replaced were also great in the snow, and were significantly quieter than the Pirellis, but were too expensive for my budget, so I settled for the Pirellis. Both are fine all-season tires that were highly recommended by Consumer Reports and users. The Continental Extreme Contact tires on my '01 S-Type also work well in snow and bad weather.
If you're really concerned about traction and safety in the snow then your best bet probably is to invest in a set of snow tires - mount them before the first snow; remove them in the Spring. I think someone on the S-type forum was selling a set of snow tires mounted on rims. You might search to see if they're still available and fit your car. Good luck. Maybe see you in Philly. Steve
Last edited by Jumpin' Jag Flash; Oct 12, 2014 at 12:54 PM. Reason: corrected spelling errors
Old Oct 13, 2014 | 04:12 AM
Mine is with Continental tires and I am quite pleased. The ride is quiet and smooth. Also you may experience a somewhat less comfortable ride if you have larger than stock alloy wheels.
Old Oct 16, 2014 | 06:40 PM
You guys have a wealth of knowledge. Thank you for the time you took out to reply to me
Old Oct 17, 2014 | 07:17 AM
hilaryv215's Avatar
No problem! !!! Please keep us in the loop with what happens. Im a newbie but I like hearing everyones stories and outcomes
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
KarimPA
Sep 12, 2015 08:15 AM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
