Radio - No Sound
Old Mar 2, 2013 | 01:31 PM
brianshaw009's Avatar
Default Radio - No Sound
Hello, I just got a new to me 2006 S-Type 4.2 and the Stock Alpine stero is not working. Initially none of it lit up, changed the 20A (F18 - Radio) fuse now it lights up but have no sound. Also changed the 10A (F26 - Antenna Amp) fuse that had a 5A in it. Not sure if it should be a 5 or 10, but looked up an owners manul online and it shows it to be a 10A.
Still not working are the 6-disc changer, and still not getting any sound.
Both the 30A - F28 Power Amp fuse and the 10A - F29 CD changer fuse appear to be good.
I will be running up to the auto parts store to get more fuses and change them anyways.
There is also a brown/brown-white wire in the trunk that does not appear to be connected, I do not know if this is related to my problem. or what to connect it to.
Please Help, I want to love this fine automobile, but without a working stero, that will be diffiult.
Thanks,
Brian Shaw
Old Mar 2, 2013 | 06:28 PM
Default 2006, Checked and Replaced Fuses
Checked and Replaced the fuses in question. Read somewhere about the radio test, holding both am/fm and eject, and then eject and mix, it would not run through all the codes and only came back with code MAIN 1.0050, after looking that up, it looks like it may be a bad amp.
Has anyone experiencted this or replaced the amp?
Anybody know where the amp is located? (is it the unit above the cd changer in the trunk)
Thanks,
Brian Shaw
Old Mar 10, 2013 | 01:42 PM
Default No Power to CD Multidisc
Ok, so if this system is a fiber-optic loop and there is an issue with the cd multidisc player (no power, fuse is good, cannot eject cd's, no light on eject button), can I just bypass the cd changer to complete the optical circuit?
Old Mar 10, 2013 | 03:44 PM
Default Fixed
To answer my previous question.
Yes you can bypass the cd changer in the fiber-optic loop.
I now have a working stereo with sound sans the cd changer.
Old Mar 10, 2013 | 04:02 PM
hafferf's Avatar
Hi brianshaw009!!...
I would like to congratulate you on a fine job of helping yourself.
I'm suprised that nobody helped you out sooner. The knowledge on this site is impressive with large amount of DIY experience. Let me welcome you to the site and welcome to the S Type experience...
Drive on!!...
Fast Freddie
Old Mar 11, 2013 | 05:43 PM
its ok, Thank God they are cars and not space ships. When we get stranded with obstacles, we can walk away.
Old Sep 22, 2014 | 11:50 PM
JAGUAR03SS's Avatar
Default no stereo sound
I have a 2003 jaguar s-type R, comes with premium sound stereo. I lost the sound everything else works, i think my amplifier is burnt due to a leak i had in the trunk, i noticed the amp with some water on the top of it. Please if anyone knows how i can hook up a different amp to it or if i can bypass the amp i would really appreciate it.. please help.. thankxx
Old Sep 23, 2014 | 01:41 AM
JagV8's Avatar
Wreckers should have them. Probably the cheapest and easiest option.
Old Sep 24, 2014 | 01:09 PM
oldtvman's Avatar
I've serviced consumer electronics for over 45 years. If your looking to swap out the amp check with electronics suppliers and see if they have a wiring harness that will adapt to your current head end unit. If you can find that the job becomes very simple. You may have to get the model number of the alpine system to be able to cross-reference that harness.
Old Feb 24, 2015 | 01:04 PM
nebre8's Avatar
Default how to bypass CDC?
Am I missing the part of the thread that explains how?
Old Feb 24, 2015 | 01:58 PM
I don't know but I'd guess he just took the cd changer out of the network loop and connected the previous device directly to the headunit.
Old Feb 24, 2015 | 03:29 PM
nebre8's Avatar
Well that would be fine and dandy, but my reading around the forums suggests there is some proprietary Jag black magic at work that makes trouble for you if the system detects anything not in its expected place. Certainly my experienced Jag mechanic is still scratching his head and another Jag specialist place told me that they outsource all audio work to car stereo specialists rather than deal with the Jag system.
I'm just super annoyed because it was all working fine until I unjammed the CDC. Who knew the plastic carpet tack in the changer mechanism was keeping the whole system working!
Old Feb 24, 2015 | 03:53 PM
Yes demons may be there, I understand that a non Jag Alpine changer won't work but it surely sounds like he just skipped the changer out of the loop.
philwarner
Oct 4, 2024 01:37 PM
pilot435
Apr 8, 2016 06:16 PM
al_roethlisberger
Sep 21, 2015 08:15 PM
Lannyl81
Sep 20, 2015 08:56 PM
Burdedw
Sep 12, 2015 10:39 AM
