Rattling sound in passenger side
Old Mar 13, 2008 | 04:08 PM
super_jag's Avatar
Default Rattling sound in passenger side
I changed my brakes about 2 weeks ago, but now it squeaks like it their is no tommorrow and their is a rattling sound, more like when you are drying you clothes and their are coins losse inside the dryer. Any thoughts? comments?
Old Mar 13, 2008 | 05:25 PM
jag_genius's Avatar
Default RE: Rattling sound in passenger side
did you install the tension clips on the pads? most aftermarket pads don't have them.. hopefully you dint throw them out
Old Mar 13, 2008 | 05:41 PM
super_jag's Avatar
yes i did, I thinking of not doing it but i installed them anyway.
Old Mar 14, 2008 | 07:41 AM
FactoryJaguarTech's Avatar
Aftermarket pads, especially autozone specials etc are a little smaller than the factory pad. Even with anti rattle springs installed, they move around and make noise. If you want aftermarket pads, I hear great things about Akebono pads or go with factory ones. Also check the dust shield and make sure it is not loose or you didn't bend it so it contacts rotor. I have also had a couple of them that the bolts holding the caliper to anchor bracket werent holding it properly. Maybe stretched. I replaced the bolts and noise disappeared. Not common though. I would say if aftermarket pads, they are moving in caliper causing rattle.
Also - If they are directional pads - ie angled on top or bottom of pad, make sure the angle part of pad is at bottom. If you put pad in upsidedown could cause rattle also. Everyone has made that mistake once.
Old Mar 14, 2008 | 09:31 AM
super_jag's Avatar
Actually you hit it dead on, I purchase my pads from Autozone, the cheapies, until I get some new cross drilled rotors I 'm thinking on buying.
I checked the heat shield and it was fine....
I checked the pads and the seem real secure...
I will remove the wheel and pad tommorrow. As a matter of fact I did bend one of the retaining clips a lil because it won't stay on the pad, it kept coming off.
Old Mar 14, 2008 | 11:49 AM
Get factory pads. They come with new clips and new bolts.
Old Mar 14, 2008 | 12:11 PM
jagxtype's Avatar
your rattle sounds a lot like a swaybar endlink. I place my money on this one!
Old Mar 14, 2008 | 02:46 PM
Didnt come up until brake job. Not likely it is a coincidence. Seen it a hundred times people using after market pads and they rattle. S-Types are the worst for it because of the anti rattle clips. The suspension on the S makes more of knocking noises than rattles.
Old Mar 14, 2008 | 04:40 PM
jagxtype's Avatar
you know more than me bro. I just figured with the car being jacked up it flexes the suspension and could cause the joint to overextend and become loose. I have seen it a million times on other cars. Not sure about these though. Good looking out!
Old Mar 14, 2008 | 08:41 PM
jag_genius's Avatar
i like when people come to our shop and ask for the clips.. haha
Old Mar 15, 2008 | 02:50 PM
I tell them only way to get them is buy the pads. Oooorrrrrrr........I have a set right here........
Old Mar 16, 2008 | 09:39 AM
jag_genius's Avatar
yea for some $$$
Old Mar 16, 2008 | 09:47 AM
always $$$
02jagstype
23
Oct 23, 2022 07:03 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
