Rear seal
Old Dec 14, 2023 | 08:08 PM
lhjones's Avatar
Default Rear seal
Does anyone know the approx. cost or required hours necessary needed to replace the main seal on a 2005 S type 4.2.?
Old Dec 15, 2023 | 07:07 AM
Peter_of_Australia's Avatar
...and what do you call the "mail seal", aka "rear seal"?
Old Dec 15, 2023 | 08:45 AM
clubairth1's Avatar
Community Influencer
Can you DIY the job?
If not get ready for a huge bill and most probably a repair job that will cause additional problems.
Old Dec 15, 2023 | 02:23 PM
motorcarman's Avatar
Remove gearbox, remove torque converter drive plate, replace seal, reverse and reinstall all components?
Old Dec 15, 2023 | 03:01 PM
scottjh9's Avatar
I have an 06 s type r. Same 4.2 in essence. I needed my torque converter replaced and was quoted 6.5 to 7 hrs or about 750.00 dollars. The seal replacement would probably add one more hr. I ended up doing it myself once i figured out how to get to the top 6 bolts. Still the quote i got was from an indie i trust and is always more than fair. I just did not have the extra money and i am a diyer or i could not own this car
Old Dec 15, 2023 | 05:36 PM
Do all of you really know, what the initial question is about? Do all of you know exactly what the "mail seal" or "rear seal" is, or does everyone give an answer based upon what there interpretation of "mail seal" or "rear seal" is? To put this to an extreme: I would also call the seal around the backlite (=rear window) a "mail seal" or "rear seal". Just like many other seals could be called that instead of using their proper names... Yes, my first idea, of what the question was about was the rear crankshaft seal, but as said: There are a lot of other rear seals.
If the question is indeed about the rear crankshaft seal, then yes to what motorcarman wrote - I am doing exactly that at this very moment on my van, and same story: Propeller shaft removed (which I assume applies to the S-Type as well), transmission removed (I converted a big car-jack by bolting a massive steel plate onto it to a transmission-jack. I did the same transmission removal years ago without that jack and wrecked my back by doing so), and as my van is a manual, then removed the pressure plate and clutch disc and also noted that the bearing for the transmission inside of the rear end of the crankshaft has "dissolved" and replaced that.
Old Dec 16, 2023 | 09:46 AM
S-Type Owner's Avatar
Well, the OP does not appear to be a "frequent flier" on the Forums; his immediate prior post was in February 2014; it was also relating to the time required to do a repair. Perhaps he just uses us to check on quotes from his mechanic...
Old Dec 16, 2023 | 10:45 AM
clubairth1's Avatar
Hey scotjh9 good job! Did you make a thread on that real main seal replacement? I have not done one on a Jaguar and was not sure how different it was from the old American V-8's I am use to working on.
Old Dec 17, 2023 | 05:33 PM
davidladewig's Avatar
I got a quote from a transmission shop here. $850. It is a ford seal so you won't have to pay double like Jag dealer would charge you.
etaent
XJ40 ( XJ81 )
Nov 25, 2023 03:06 PM
Felixbobcat
Apr 12, 2023 05:56 PM
oldole
Feb 25, 2023 05:34 AM
Darrenmb
Mar 19, 2022 07:49 PM
sambella
Oct 1, 2014 03:02 PM
