recharging air conditioner
Old Apr 12, 2011 | 11:57 AM
georgia boy's Avatar
Default recharging air conditioner
i have a 2000 jaguar 3.0 s-type.
here's my problem. i would like to recharge my ac but i cannot find the port. where would it be located? thanks in advance.
Old Apr 12, 2011 | 02:25 PM
VMV's Avatar
VMV
GB, The AC fill port is on the AC compressor down at the lower left front side of the engine compartment.
VMV
Old Aug 24, 2011 | 03:32 PM
Jag_man81's Avatar
Default a/c port
hey do you have a diagram or pictures where it is located?
Old Aug 24, 2011 | 03:34 PM
motorcarman's Avatar
Look on the side of the compressor for 2000 - 2002
If you are asking about a 2004 then it is in the rear of the left wheel well area.
X200 are different from the X202
bob gauff
Old Aug 24, 2011 | 04:52 PM
Gus's Avatar
Gus
See if this link helps A/C 2000 S-Type
Old Aug 24, 2011 | 05:26 PM
tot's Avatar
tot
On my 2001 it is on the compressor, pointing towards the wheel. In practice the wheel has to come off to access it.
Old Mar 13, 2012 | 09:17 PM
NewJagGuy's Avatar
This post was very helpful.
Old Mar 13, 2012 | 09:36 PM
QuartzSTypeR's Avatar
Originally Posted by NewJagGuy
This post was very helpful. My 2001 S type air conditioner stopped cooling over the winter. You can get to the low pressure valve by turned the front wheels all the way to the left. Then get on the ground and look behind the drivers front wheel. The valve is on the compressor behind a flexible flap which you can raise up. There is a black dust cap covering the valve. My compressor was not running but after adding 18 oz of r134, it engaged and begin to cool properly. Price was $24 at Walmart for the 18oz can with a hose and gauge. Was much better than a trip to the garage.
If your car was a pound and a half low on R134, I would heavily suspect there is a leak in the system. Did the Wal Mart R134 have dye in it?
Old Mar 13, 2012 | 10:03 PM
NewJagGuy's Avatar
I was concerned about additives after reading some other posts. Do you recommend I try the dye to locate the leak?
Old Mar 14, 2012 | 05:15 AM
joycesjag's Avatar
How do you know that you haven't over charged the system? The dye will do no harm.
https://www.jaguarforums.com/forum/s...ics-faq-55219/
Old Mar 17, 2012 | 08:51 PM
NewJagGuy's Avatar
So far so good
Old Jun 21, 2020 | 12:45 PM
Johnny V's Avatar
I hate not seeing pics, but yes on my '02 3.0, its on the compressor pointing inwards (shrader valve is a M8). You will need a ramp or jack, different of the newer models where i see them turn the wheel. I aplogize if the pic is too large.
Old Jun 22, 2020 | 11:29 AM
Gus's Avatar
Gus
All of my work was transferred to JagRepair.com - Jaguar Repair Information Resource many years ago. Hence the problem with not starting a new thread and electing to piggy back on an old thread.
See if this link helps JagRepair.com - Jaguar Repair Information Resource
scooternva
29
Mar 25, 2025 12:45 PM
scooternva
19
Oct 27, 2015 02:14 PM
Poet
Oct 6, 2015 09:40 PM
mel
Sep 20, 2015 04:56 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
