Recommended oil?
Follow the manual for viscosity and API recommendations. Beyond that, choose which type (synthetic or dino) and which brand pleases YOU the most. The car couldn't care less.
Prepare yourself for dissenting opinions.
Use oil which Jaguar recomends. I use Motul Specific 913D - in my opinion perfect oil to this engine. My engineering work was about oil's. I compared synthetic oil with the semisynthetic.
But overall rule is that the we must use oil which company recomend to engine. For example Motul, Millers, AMSoil, Royal Purple, Penrite, Mobil 1 use a full synthetic (PAO base) even with small mix of ester. Valvoline, Liqui Moly (not all) uses mix of PAO and hydrokrack base. Castrol, Mobil Super, Fuchs they are use only hydrokrack base. But the Fuchs in my opinion has the best quality of the three.
The only oil that meets the requirements of Ford with 5W40 viscosity is Penrite HPR, so you can use it when you have a agressive style of ride. But overall the 5W30 is completely enough
PS.
I have a small deviation in this oil topic
PS.
You will get several opinions on what you should and should not do and that is all good. I would suggest that you look at your owner’s manual and look at the viscosity ranges based on the temperature zone you live In for your you will see what is recommended. As for the oil I have been using Mobile1 Synthetic and am pleased with the results. I will provide a link so you can read about oil if you wish.
Link Used Oil Analysis - Bob is the Oil Guy - Bob is the Oil Guy
aholbro1
Dec 29, 2024 06:46 PM
